[Z06] '11 C6 Z06 knock sensors and detonation
I cannot find any information on this subject. Are the knock sensors underneath the intake manifold in the V? I have an obd2 bluetooth device that lets me log pids but there is no pid for the knock sensors, however this could just be the device not picking them up.
Car has heads/cam. I'm getting what I think is detonation at 50%-100% throttle in 2nd and 3rd gear. Fairly distinct sand in a can type of sound. It goes away pretty quickly, within 1-1.5 seconds. I've never heard detonation before, so it possible this is just exhaust related, although it's completely stock exhaust. No codes or CEL.
Any advice is appreciated, thanks!
Knock sensors on Gen IV's are located below header's on each side of block.
Not device, but software not reading the knock sensor data...Might want to check if they have custom pid setup available...
When was it tuned?
Has the car been sitting, and perhaps has old or winter blend gas?
Try running out the current fuel and get fresh fuel and see what happens.
When was it tuned?
When was it tuned?
When was it tuned?
Has 28k miles, was probably tuned around 23k miles when the previous owner did heads and cam.
I'm going to get it retuned for peace of mind, just trying to do my due diligence before I take it to them.
There are some custom pids I can use, but I was curious as to why it wasnt showing up on the standard list.
Knock Retard is the PID you monitor for knock.
As said above, sensors are on side of block on gen 4/5, gen 3 they are in the valley.
Degrees of retard
Thanks guy! I'm starting to think that this sand in a can sound is coming from my cats... It is not a rhythmic sound at all. It's very intermittent and only when under heavy load, so above 3k rpm and more than 80% throttle. Sound is directly below and a little in front of where the shifter is. Audible with the windows up and I can also hear it outside the car if I have the windows down while doing a pull. This sound doesn't happen ANY other time while driving the car.
Sooo...coins in the cup holder...
Removed coins...no more sound. Put the coins back...sound comes back...
I thought I had checked this when I was diagnosing the sound, apparently I didn't though lol.
"uh yea, was a loose kanuder valve spring keeper, took some ball bearings and 30 weight oil to fix"....
