[Z06] Highest HP with BTR 3 cam???
Curious what others have seen as far as MAX HP with the BTR 3 and all supporting mods. I was looking to maintain some fairly good drive-ability by sticking with this CAM.
Car currently has the following mods and put down 562whp/522wtq SAE:
AHP street ported stage 4 head pkg (resurfaced; no milling)
BTR stage 3 camshaft
Halltech MF 103 intake
FAST 102 manifold ported by Jeremy Formato
NW 102 TB
Stock injs
Kooks 1 7/8" LT's w/ catted midpipe
Burns axle-back exhaust
The mods that I will be installing shortly are:
ID 850 injectors
ARH 2" LT's w/ catless midpipe
MAMO ported MSD intake
Advanced Induction CNC'd heads milled .030-.040 to bump up the compression a bit
AT THIS TIME I do not "plan" to do flex fuel but I've been known to change my mind
NW 102 TB
Stock injs
ID 850 injectors
Beautiful car.
Down here in San Antonio FBO BTR 3 cars lay down something like 625whp and 550wtq on e85. That dyno reads a little higher than most (so people say).
I don't have the most optimal setup but I made 580whp/545wtq just recently.
My mods are:
LPE ported heads
.050" mill
TSP 1-7/8" headers
3" x-pipe
BTR 3
Mamo MSD
NW102
Halltech 103
ID1000s
Flex Fuel
The most noticeable difference was when I added the Mamo MSD. Really woke the car up. I just changed out the Halltech for a Vararam and it feels a little stronger (SOTP).
Curious to see what you pick up with the change in parts. That's the route I am thinking of going. ARH 2" headers and AI heads.
Do you have a dyno graph of where you sit now?
My mods are:
LPE ported heads
.050" mill
TSP 1-7/8" headers
3" x-pipe
BTR 3
Mamo MSD
NW102
Halltech 103
ID1000s
Flex Fuel
jayyyw (05-17-2017)
MSD 10-15 hp
Heads 10-15 hp
Rough estimate of what you may gain potentially. Really interested in seeing your results. Good luck!
My cam is less aggressive then the stg 3 with less overlap and I made 618rwhp on e85. Our dyno is very conservative also, often a heart breaker for most. I think you could get to 585-590 on pump and 605-610 on E85 with a healthy compression bump.
I think 95s power gain numbers are all a bit low. Those AI heads really shine and love to make power. The mamo MSD has shown 20+ time and time again, especially with good heads and decent size cam.
Wouldn't be surprised if you saw 630ish on a dynojet (assuming enough octane).
575 rwhp on 21st century's Dyno jet.
WCCH heads with cbc porting BTR 660 springs.Milled .010
LS7 lifters
Radial ported stock intake and ported TB
LG 1 7/8 coated super pro headers, no cats, LG x pipe, stock mufflers.
LS7 lifters
My set up is fairly close to yours.
AHP stage 4 package with all the goodies & milling .30
BTR stage 4 cam
BTR duel springs.
Yella Terra roller rockers
Kooks 1 7/8 headers
Callaway CAI
Corsa extreme exhaust w/ full flow cats
Made 575 RWHP on a mustang dyno
BTR stage 4 cam
BTR duel springs.
Kooks 1 7/8 headers
Callaway CAI
I made 625 SAE Smoothing 5 on a dyno jet on e85 w/ AI stock ported heads, BTR Stage 3, 2" ARH, Vararam, Mamo Ported MSD, 102 NW TB. I switched to a Stage IV BTR Cam and made 641 SAE Smoothing 5 same dyno, wheels, temp, etc. Mamo MSD is worth every penny if you are considering it.
Any updates?
