[Z06] Clutch job turning into a nightmare
I had the same problem. Hinson remote line was leaking at the slave. Not sure why. The line it self fit for crap. Im sure it was hitting the tunnel at times under power pulls. I would have used a Ktech but didn't want to wait so I just went with out it and use the stock bleeder. Its a little more work to do bleed it or flush it but I know I will not have that issue again
Still waiting on the shop to work on the car. My patiences are wearing thin... I called yesterday and got blown off again. Almost ready to publicly blast the shop 😡.
He said he bled the system before installing the torque tube and there were no leaks. Tells me with 99% certainty that he hit the bleeder line when he reinstalled it
Wishing you luck.
Hope it is something simple to repair.
FWIW sometimes it is just not worth supplying your own parts for a shop to install
That brings about the situation you are in.
If the shop installed the bleeder or pinched a line we'll soon know their credibility. If the parts were faulty, well you are in for double labor.
Again wishing you good luck.
After doing my own i definitely can see how the remote bleeder could hit the tunnel and/= crack or break off right at the slave. I have the shorter hinson engine mounts and its still pretty close.
OP, fwiw nothing is probably broken or damaged. The remote bleeders simply hit the tunnel over a little time and back off and start leaking. The katech ones are the only ones that don't. That's why it didn't start till after you drove it. I could be wrong, but I have seen this numerous times on these cars.
FWIW, Katech bleeders are not the _only_ ones that don't leak. Mine is not Katech and it doesn't leak. Unfortunately, I'm not sure what brand mine is. The fitting is slightly angled that goes into the slave.
Or first time cars drivetrain tweaked, it is close enough that it cracks the fitting. Seen that too.
If someone brought me a cheap set of china headers, I put them on, and then 500 miles later they crack, should I be responsible for replacing them or the labor? Nope.
CPR uses their own bleeders made by local place, and they are good, but they provide them, warranty them and install them, so if there was an issue, its on them.
#33
I finally showed up in person because he has been avoiding me. Among the other things he said, he told me that he doesn't think it has been leaking the past two days when they have been moving it into and out of the shop. I really wonder exactly wtf is going on. He told me he needs to get 5 other cars done to pay the rent this month. He already has my $$ so wtf does he care about fixing it now...
#34
I don't see this going smoothly if the business is literally 1 job from closing the doors. Even if he did cause the issue, he won't be able to afford the repairs.
Being around San Jose, CA area you could make some assumptions.
#35
I would be careful doing that. If he publicly ran him down it could hurt his possible legal case against him. If you wait until the case is closed and there was no hush order in the agreement then tell all you want.
#37
#38
Don't do anything yet. You really need to find out what happened and what he plans to do about it first. At this point there has been no determination of what actually went wrong.
#39
So what if we played it your way Joe? If he loses money for naming the shop are you and anyone else in the area going to fill that loss? Didn't think so. I'm just trying to help the OP out. I can't with a clear conscience tell him to give us the shop when I know what could happen if he does. Any legal council will tell you this. I feel like maybe the shop owner is just being honest with him. Maybe money really is tight. Its the 26th already. He needs 5 more jobs this month to keep the doors open. Beginning of the month (less than a week away), he may be right on this. I understand that this situation may be angering and leaving the OP feel concerned and anxious but some things take patience.
