[Z06] CEL error codes
CEL error codes
Got the car back from the shop today and now it has the CEL light on. The code is:
P0174 - System too lean (Bank 2)
P0171 - System too lean (Bank 1)
Says the most common fix to this issue is to Clean the fuel injectors. What do you guys think?
Is it a matter of cleaning the fuel injectors and this code clears up? Or is it a problem with my tune or what? I also noticed for the first time today on my drive that when coming to a stop in neutral the RPMs go from 800 and then jump up to 1300 and stay there for about 10 seconds, while the car is at a dead stop, and then the RPMs drop back down to 700 which is what they are normally at. It does this now every time I am rolling to a stop in neutral. It'll be 700 RPMs and as the car comes to a complete stop the RPMs jump up to 1300 and then after 10 seconds back down to 700.
Tune issue, or vacuum leak. More likely the first. You don't have a cam, or any special parts, so idle should be rock solid.
I spoke with the shop today and they suggested it was a vacuum leak. They told me to do a test where I spray brake cleaner at the throttle body and intake where it meets the heads while the car is idling and if the rpms raise then it would suggest a vacuum leak. So I did that and every time I sprayed brake cleaner right on the throttle body (where the intake meets the TB) the rpms would raise slightly. So does that sound like a vacuum leak?
The problem is I looked at all the connections/hoses in that area and everything seems tight so I'm not sure where the leak is coming from or how to address it.
