[Z06] And it begins
And it begins
Well I am currently in the process of taking my heads off my 07 Z06 and getting the valve guide issue taken care of, and in the process figured why not just go ahead and throw a BTR stage 3 cam in her as well. Havent got the front of the motor apart yet, but I figure ill take some pics and maybe help other with the LS7 cam install guide with pictures since I cant seem to find one anywhere.
Here is the link to Head and Cam replacement. https://www.corvetteforum.com/forums...full-pics.html
I notice in your picture you have the stock exhaust manifolds. Not sure what the rest of your exhaust is stock or not. Are you planning on make changes to it? I recommend you check with other people who have this cam and find out what exhaust they are running. I suspect they are all running headers and no cats.
Yea its a pain in the *** for the cam install, but with the heads probably going to take a week or so to get finished ill have plenty of time to tinker around in there and get it done. Plus nothing better than building it yourself knowing you did everything correct.
You might want to work on those decks a little more...unless this was a before cleaning picture that is.
Received 1,679 Likes
Wish I had those kinds of mad skillz......
OP, who is reworking the heads, and what are you having done? i.e. - valves used, springs used, guide materials, springs, porting, milling, etc.
Good luck!
Good luck!
This is my first head work job. I usually stick to the light stuff, brakes, belts, alternator exhaust and shock & struts. About as far as I have gotten internally was adding plenum spacer kit on my SUV. But seeing how this write-up was well written and this is not my daily driver, I felt I could take my time. I thought about doing the cam, but thought that might be a bit much for me at this time. Let's see what happens when I crank her for the first time
Whats the best thing to use to clean the decks? Ive seen multiple things people use just want to know what is the best method.
I used a plastic scraper, it worked real well for me and got off 90% of the old gasket with ease. Wet/Dry Vac in one hand and scraper in the other, only a thin residue was left, which cleaned up nicely and effortlessly with Goof Off, I followed that with brake cleaner to get any residue the Goof Off left behind. I was to scared to use the razor technique
Got the heads off and everything pretty much out of the front to allow me to pull the water pump and get the rack out of the way to allow me access to the crank bolt.
So quick question im still up in the air about this, but are Texas speed headers worth a **** or should i just pony up the cash and get some stainless works or Kooks? I know they are stainless steel and all that now but how do they compare to the other brands?
X-Pipe, exhaust? If you plan to keep stock X-pipe and want a direct bolt on without having to modify it then you may want to consider B&B LT header as it is the only direct bolt on to stock H-pipe. Likewise, when I bought my 2008 Z06 it already had the Akrapovic Evo exhaust system, which bolt directly to the stock headers. I didn't want to modify Evo X pipe or headers so I had no choice other than the B&B LT headers. Something to consider
Yea thats the main thing I notice is TSP doesnt offer a 2" only the 1 7/8 or 1 3/4. Guess if I am going to do it might as well do it right. Anyone here have stainless works? my friend loves his and want to get more opinions on them.
ARH, LG, or Kooks IMO. The TSP headers are probably alright for most, but the mid-pipe that they use is just plain odd looking...the "X" section is towards the rear of the mid-pipe, rather than up near the header collectors. Everything I've read about the benefits of a "X" for scavenging purposes is that it should be as close to the header collectors as possible. The TSP "X" looks to be like 3 feet away from the collectors. Just my observations for what its worth...
