[Z06] Front/Rear Calipers Interchangeable
Max G’s
I did a search and could not find anything; Are the front and rear stock z06 calipers interchangeable. Basically, could I put 13" rotor and rear calipers on the front with just bolting them on or would I need modification to the knuckle? As well, could I put 14" rotor and front caliper on the rear?
Pro Mechanic
Never thought about it... but on a C5, I've heard of some track guys running front brakes on the back too, and since the C6Z brake package bolts directly to a C5... might be a logical assumption that it could work.
You could try it... but I won't ask why
Max G’s
I know the 6 pistons probably would not fit the 13" rotors. I would figure to use 13" rotors and 4 piston calipers on front. Same parts as used on rear.
Rears are the ebrake integrated into the them. Drum style inside the rotor. So at the very least you would lose the ebrake.
Max G’s
Max G’s
Max G’s
OK, now after reading in the FSM, looks like the C6z uses the ABS Systems DRP (Dynamic Rear Proportioning) control system to regulate the pressure to the rear brakes.
So it appears that this is what controls the bias front to rear. So, if 13" rotors were used on the front and rear; bias should still be controlled and keep the rears from locking up. Am I correct in thinking on this.
Pro Mechanic
Rotor diameter is one part of the equation, caliper piston area is another. Don't know how much of that 'DRP' electronic control is a programmed function and how much is reactive/adaptable from the ABS signals. Either way, I can't believe it would have the capacity to modulate out THAT much mismatch.
Please try it, and report back!
Well, if you are taking it easy, you may be able to keep it under control. However, The first time you have to stop hard, you will spin. Trust me, I've put front calipers on the rear of my racecar. It was un-drivable. The front of the car takes way more of the braking load and therefore needs way more stopping power. Systems have to be designed to work together.
Trust the people who have raced cars for years. You have both myself and David Farmer telling you it won't work. Call LG and ask him. Doesn't work!
Robert Finlayson
Robert Finlayson
Robert Finlayson
Received 2,060 Likes
Just for reference, a base C6 has the same ABS, yet it supports two other brake sizes. The JL9 and J55 have different size rotors, with the fronts being .6" different, but the rears are a full 1" different. Even though the rear caliper physical size is the same, the piston size is different to create the correct F to R bias. If the ABS controlled the bias, there would be no need for GM to have different piston sizes.
If you want to experience how changing the bias would feel, just put some cheap ceramic pads on the front and some fairly aggressive track pads on the rear and find a safe place to test the difference.
Max G’s
Thanks for replies. I may test the use of 13" rotors and calipers on the front next season. I just installed new 2 piece 14" front 13" rear so these will survive the rest of the season.
If most of what is being stated with regard to using different sizes is in fact correct; I feel for the guys who have spent $5K for new big brake kits.
C2Racer (05-23-2017)
Max G’s
The goal is lower weight, decrease rotating mass, and be able to heat the brakes up quicker. This Z's primary focus is autox.
