[Z06] Oil level 08 Z06
Oil level 08 Z06
Just had an oil change and as usual I checked the level when I got home.
It is about 1" above the full dot. With this Oil system in the Z is this a major problem. Will the oil foam if I am not tracking the car? I guess I am asking if I can ignore the fact that is overfilled. (because it is a dry sump system)
KarlM100 (05-26-2017)
I would drain the fill tank and go from their. I think it holds about 2 qrts. That is if you can do it yourself. If not I would be making a phone call to whoever changed it.
Oil level
Why can't I do it myself? I know it has 2 drain plugs.
Can I drain either. I think it is 1 quart overfilled.
My 2007 will read little or nothing after sitting long enough to be cold. I think 2008's are the same. I suspect they only drained one of the plugs.
With 8 qts after a chance, warmed up and waiting 10 mins it reads 1/2 to 2/3 between add and full.
If you checked it cold then it is even more over filled than you think. I would not start the car. I would have the mechanic tow your car to his facility and correctly fill it. I would also document the whole thing incase you start having any problems with the motor.
DH
DH
Received 8,926 Likes
Bill
Oil level
Thanks everyone.
QUOTE=1972bluelt1;1594827420]My 2007 will read little or nothing after sitting long enough to be cold. I think 2008's are the same. I suspect they only drained one of the plugs.
With 8 qts after a chance, warmed up and waiting 10 mins it reads 1/2 to 2/3 between add and full.[/QUOTE]
As long as the oil is at one the the 3 holes on the dipstick 5 to 10 min . after driving to oil temps over 170 you're fine. That's why I dont' trust 99% and do my own. I understand some can't and it's unfortunate you get al lot of guys that work on old toyotas all day. If me... id just lay the price at the stealership. It should be done right at a nice price of 3 digits.
