Greg, cool that you weighed in. We've been doing work with piston dome designs on the LNF and 2.3 disi mazdas that intercept the spray pattern for an increased dwelltime when the piston is around tdc. This goal being a longer pulsewidth before and after tdc and give the tuner a improved mathematical window to inject fuel .
We usually try to avoid any inpingement whatsoever on the bore, piston crown or cylinder head. While we never truly get to zero, it's at least something to shoot for. Whenever liquid fuel hits a surface, it's generally bad for combustion quality since it starts causing rich spots in the chamber (likely accompanied by some other area of the chamber being the mirror image lean too!) and requires some compensation for impact and evaporation like we do in port fuel systems. Liquid gasoline also does bad things to port walls that depend upon an oil film to reduce friction.
...some have done a secondary injecting event btdc at the end of the compression stroke and a small portion atdc into the powerstroke before combustion pressure overcomes fuel pressure. I don't know if this does any damage to the injector itself, but considering what diesel injectors go through....probably not.
This is usually done for cold start catalyst lightoff improvement, not necessarily "normal" operation at warm engine temps and a target of stoichiometric operation.
I've also seen some people talking about modding the pumps. We have some customers blueprinting the factory mechanical pumps and apparently extending the window. Because of the sheer volume of programmiing by the o.e. under different conditions, I'm wondering if there are any "constants" that can be changed in the GM software that rewrites all the pages at once rather than making one page right and 200 wrong. Testing a revised aftermarket fuel pump flow curve as accurately as the o.e. isn't an easy feat.
Any thoughts on these things?
I'm not 100% certain yet as to how GM models the high pressure DI pump. I know that at VDO, I had two different models I could pick from that were either linear (two point) or progressive (five point). Each of these had the ability to learn a set of trim values to account for build tolerances and wear with age, but still required that the base (feed-forward) values were relatively close to what the pump actually did. I was also using a six piston crank driven HPDI pump with an inlet-side pressure regulator as opposed to what appears to be a Bosch single piston HPDI pump with an outlet side regulator running on a three lobe cam. Obviously, whatever cal values GM uses in the ECU will be tailored toward the hardware they spec from their suppliers. If you drop in a high volume aftermarket replacement, I would suspect it will need the matching calibration values remapped in the ECU.
I heard that GM is aware of the issues people have had modding DI engines - significant mods to fuel delivery system and lack of aftermarket parts to support that. Supposedly, because GM is aware that Corvette owners mod their engines, GM has stated that the stock fuel delivery system on the LT1 will support 800 hp. Now, it might take some time to figure out how to get that extra fuel out of the stock system.
