C7 Stingray with Magnuson Heartbeat 2300 supercharger now making 631rwhp 662rwtq
I installed a Magnuson Heartbeat 2300 supercharger on a bone stock 2016 C7 M6 and made 562rwhp 591rwtq.
Here's the thread from December 2015: https://www.corvetteforum.com/forums...-stock-c7.html
Recently, I added some Texas Speed 1 7/8" long tube headers w/cats and then some high octane unleaded fuel so we could add a little more timing. The results were 600rwhp and 616rwtq. This is still at 6.0-6.5psi boost.
Next we dropped from the standard 87mm upper pulley to the smaller 78mm pulley supplied by Brian from Superchargers Online. The smaller pulley increased blower speed so we were now running 8.5-9.0psi boost. Running 15 degrees of timing, we made 631rwhp and 662rwtq. With 91 octane fuel, the results would have been lower, but this shows the potential of the Magnuson Heartbeat 2300 with headers and no other mods. Very stout indeed and still drives like stock. Look at that monster torque! The dyno comparison shows the difference between the 87mm standard pulley and the 78mm pulley.
Supporting Vendor
so you have 15 degrees of timing in it on 91 octane with 9 psi. Am I reading that correct?
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
blown81bu (07-25-2016)
wow....impressive
With stock exhaust manifolds and cats and the 87mm pulley, the car ran 11.1 @ 131.50mph so I would expect that with headers and with the 78mm pulley, the trap speed would be 134-135mph. It's hard to ET well with a manual transmission and a track with poor prep but the mph on an 80 degree day tells the story.
must be nearly impossible to keep the tires from spinning with that much torque down low.
CorvetteBrent (12-27-2021)
An aftermarket cam is always a possibility. Actually, I've been kicking around the idea of going solid roller, but there are no good options for adjustable C7 rocker arms at the moment.
Yes, I'm still running the stock air filter box/filter along with the Magnuson smooth intake tube. I swapped the stock air box with a Halltech C7 Z06 CAI (it fit) and I sadly gained 0rwhp on the dyno. Same dyno. Same day. Actually, the Halltech leaned out the mixture and showed a loss on the dyno, but after I tuned it to get the air fuel back to perfection, the power was back to what it was with the stock airbox. Swapping back to the stock airbox had the power return to the same baseline. I was shocked too after all the hype surrounding the new C7 cold air intakes. I expected at least 10rwhp gain, but received nothing. I guess the stock intake with a smooth tube is not the cork that others say it is.
I know the stock filter/MAF system flows right about 585 CFM at 8"H20, so it seemed possible that at your output there might be some benefit to increased flow. I have an aftermarket system for my Z06 sitting in the box, I'll make sure to throw it on the flow bench before it makes it's way onto the car (and dyno).
ajrothm (08-08-2016)
Wishful thinking on my part, 10HP seemed reasonable... but not at all surprised about the change in the MAF transfer function toward the lean side, easily more responsible for power increase on a stock vehicle compared to the actual airflow increase.
Since the stock Z06 is very rich from the factory, this is most likely why the Halltech shows a gain in an untuned configuration. The leaning out effect is what gives it most of the power gain and a stock untuned C7 Z06.
Nice my shop were I'm installing LT4 blower said don't need meth either with a lower pulley great results man lookin to get similar gains
brookfield (07-28-2017)
