C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
P1SC1 & Meth dyno numbers
Old 09-13-2016, 04:33 AM
jake07Z06
CF Senior Member
jake07Z06's Avatar
Default P1SC1 & Meth dyno numbers
Mods are P1SC1, 3.85 upper pulley, meth, main cat delete, catless Borla x-pipe. Car sounds and drives like stock at cruising speeds.
631 & 571 at 9psi tuned by Justune
jake07Z06 is offline
Old 09-13-2016, 09:17 AM
123sugey
CF Senior Member
Support Corvetteforum!
123sugey's Avatar
Nice !! Did you do your mods in stages ? If so what were they and power
123sugey is offline
Old 09-13-2016, 09:32 AM
jake07Z06
CF Senior Member
jake07Z06's Avatar
Yes, I did the Procharger and borla x pipe first but used the supplied procharger tune so I never dyno'd the car. Ive heard on an M7 car they put somewhere in the 550 range to the wheels with that setup.
Old 09-13-2016, 09:50 AM
123sugey
CF Senior Member
123sugey's Avatar
I have the A8 and put down 534rwhp and soon will be adding meth and upping the boost.
Who supplied the main cat delete ?
123sugey is offline
Old 09-13-2016, 11:50 AM
blown81bu
CF Senior Member
blown81bu's Avatar
great power and graph looks perfect
wonder what My D1 makes...
yours likes 12.5 AFR
blown81bu is offline
Old 09-13-2016, 02:19 PM
Translator
CF Senior Member
Great STD numbers! Can you please post the SAE graph as well for comparison purposes?
Translator is offline
Old 09-14-2016, 12:16 AM
jake07Z06
CF Senior Member
jake07Z06's Avatar
Unfortunately this is all I have right now. It was a hot and humid day so Im guessing SAE numbers would probably have been higher but I'm not a doctor.
The Following User Says Thank You to jake07Z06 For This Useful Post:
Translator (09-14-2016)
Old 09-14-2016, 06:43 PM
NJ_phil
CF Senior Member
NJ_phil's Avatar
Super low end torque on that Procharger. What boost was that at?
NJ_phil is offline
Old 09-14-2016, 07:18 PM
blown81bu
CF Senior Member
blown81bu's Avatar
Says 9
Old 09-14-2016, 07:23 PM
NJ_phil
CF Senior Member
NJ_phil's Avatar
Originally Posted by blown81bu View Post
Says 9
Indeed it does.. Musta missed it
NJ_phil is offline
Old 09-15-2016, 06:09 AM
jake07Z06
CF Senior Member
jake07Z06's Avatar
Technically we didn't delete the cats, just punched them out.
Old 03-06-2019, 06:22 PM
Bmwmike
CF Senior Member
What are the wheel and tires specs?
Bmwmike is offline
Old 03-06-2019, 08:11 PM
jake07Z06
CF Senior Member
jake07Z06's Avatar
The wheels are 19X9 +44 and 20X11 +73 in textured black with Toyo R888 265/35ZR19 and 315/30ZR20
they rub occasionally but Iím also running coilovers lower than the stock suspension can go.
Old 03-07-2019, 03:02 PM
thepat
Junior Member
thepat's Avatar
damn justune makes a pretty graph even in 2016. some people still cant tune the LTs
thepat is offline
Old 03-08-2019, 09:17 AM
ricmalaz
CF Member
ricmalaz's Avatar
jake07Z06 - is your car an A6 or an M7?
ricmalaz is offline
Old 03-13-2019, 11:46 PM
jake07Z06
CF Senior Member
jake07Z06's Avatar
Its an M7
Old 03-16-2019, 07:42 PM
BrunoTheMellow
CF Senior Member
BrunoTheMellow's Avatar
Runs out of steam at 6k.
BrunoTheMellow is offline
Quick Reply: P1SC1 & Meth dyno numbers
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
