C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Z06 LT4 Supercharger installed on my 2015 Z51 Stingray!!
Old 05-11-2017, 03:37 AM
  #41
romandian
romandian's Avatar
how come torque decreases from 3000 rpm?
Old 05-11-2017, 12:29 PM
  #42
0Billy@MTI
Former Vendor
Billy@MTI's Avatar
Incase anyone of you guys are looking. We have a lot of these parts that you would need. Awesome write up by the way!!!
https://www.corvetteforum.com/forums...o-with-it.html
Old 05-11-2017, 04:36 PM
  #43
sales @ WXM
sales @ WXM's Avatar
Matt, thanks for the share!
We are now installing these same X-675hp Packages on the Stingray's for $7,999. We currently have two kits on the shelf ready for install.
If anyone is interested in this upgrade give me a call @ 513-834-6818
The following 2 users liked this post by sales @ WXM:
JerriVette (03-03-2018), managerman (05-12-2017)
Old 05-11-2017, 06:58 PM
  #44
BrunoTheMellow
Support Corvetteforum!
BrunoTheMellow's Avatar
Received 1,396 Likes on 999 Posts
[QUOTE=SpartaGus;1594713844]
Originally Posted by managerman
It's now been over a month so I thought I would report back on how the car has been performing.
Here is a quick recap.
1. Totally different car! Tons more power under 4000rpm! Boost comes on strong...all the way up to 11-12psi...Throttle response is much improved.
2. No more V4 mode! Don't miss it.
3. After driving it for a month I took it back to Weapon X because of some surging during partial acceleration (50-70%) They were able to adjust some tune parameters and the surging is gone.
4. Going to need bigger tires....lol!
5. Exhaust note is MUCH louder after the blower install!
6. Love the factory look!
7. IAT2/MAT temps get pretty hot 180-190 range..If sitting in traffic or when heavy on the throttle for a long stretch. I'm sure that the fact that there is not much air movement under the hood with the stock stingray hood does not help..I guess this is the inherited heat soak issue from the Z06....Next trip to Weapon X will be for their track attack heat exchanger and expansion tank. (AND...ARH headers!)
8. Had some tuning done on the A8 to delay the upshift to 7th and 8th gear....The car was always hurrying into those gears and then would "bog". Also had the downshift times quickened going from 8-7 and 7-6....Way better! No changes to shift times or pressures.
9. Bought a MMS Mild Z06 catch can/breather....Will work on installing this soon.
10. Bought the insulator sock for the Halltech intake...hope that will help with the IAT temps
All in all I have no regrets! An awesome upgrade that I am very happy with!
-M
I thought by running the stock LT1 cam you would be able to keep the variable timing and have it shut down to a V4? Was it a tune that made you loose it?
my v4 mode was removed with my pro charger tune. I think it's due to the extra effort it would take to safely tune it. Probably not good to run with such a restrictive exhaust and such high power levels.
Old 05-11-2017, 07:00 PM
  #45
BrunoTheMellow
looks similar to z06 dynos.
Old 05-12-2017, 08:29 AM
  #46
managerman
managerman's Avatar
I could have kept V4, but had it tuned out. Less stress on the engine and the transmission. I can deal with the 4-5 mpg less on the highway..
-M
Old 05-12-2017, 09:28 AM
  #47
olblue75
olblue75's Avatar
Wonder how well this would work on a Grand Sport and would you be in it for the same amount $ wise as comparable Z06 anyway?
Old 05-12-2017, 09:31 AM
  #48
managerman
managerman's Avatar
Would work fine. Grand Sport uses the same LT1 engine as the Stingray. I imagine it ends up being less expensive than trading up to a Z06..depreciation plus a higher initial Z06 price would be more costly, but you would have full warranty.
-M
Old 05-12-2017, 09:35 AM
  #49
olblue75
olblue75's Avatar
Default Apples to Apples
-M
Ok so it would work well that's good to know but now if you had a GS 3LT and a Z06 3LZ equally equipped would it just be easier to buy the Z06 than do the mod to the GS and keep your warranty intact?
Just checked Chevy web site a GS starts at 65k and a Z06 at 79k so 14k difference unless you found a smoking deal come tax time. I guess the biggest consideration would be if you already owned a older car and wanted to get into this power level vs buying a new car and dumping 8 grand in it right off the bat.
That would a tough choice. Guess I better start saving!!!!
Old 05-13-2017, 10:06 AM
  #50
romandian
romandian's Avatar
well, the graph i just looked at shows torque starts falling around 4300 on the z06. what cam is in these engines anyways? because it seems with a centri you get flat torque over a very wide range.
Old 05-13-2017, 11:06 AM
  #51
SpartaGus
SpartaGus's Avatar
IMO If you already have a GS I would do the upgrade, if not I would spend the extra 14K and get the Z06.
The following 2 users liked this post by SpartaGus:
JerriVette (03-03-2018), managerman (05-13-2017)
Old 05-15-2017, 01:12 PM
  #52
CorvetteKilla
CorvetteKilla's Avatar
Or you can buy a z51 get a weaponx body kit ECS/HEADERS/METH/CAMS/HEADS/HEADERS . Any wheel/tire combo you want on and get 1000whp at the price of a stock z06. On top of that have a completely custom ride with a brand new paint job thats better than any that come from chevy.
I wonder which one is better? LOL
managerman (05-17-2017)
Old 06-02-2017, 10:56 AM
  #53
olblue75
olblue75's Avatar
Does the GS share the same hood as the Z06?? if so that should help with airflow under the hood.
Old 06-02-2017, 11:26 AM
  #54
sales @ WXM
The Grand Sports share the same hood as a Stingray. We do offer Hoods a slightly more aggressive cowl than the Z06 hoods for cooling.
Old 06-04-2017, 02:27 PM
  #55
Seannyc
Seannyc's Avatar
can u give me a price on the z06 rear only
Old 06-07-2017, 02:17 PM
  #56
sales @ WXM
pm'd
Old 06-07-2017, 11:43 PM
  #57
Drew27
Drew27's Avatar
Can you put the lt4 blower on a 17 Silverado 5.3 Eddie?
edster75 (12-20-2023)
To Z06 LT4 Supercharger installed on my 2015 Z51 Stingray!!
Old 06-09-2017, 11:12 AM
  #58
sales @ WXM
Absolutely.
Old 06-14-2017, 03:00 PM
  #59
SurfnSun
SurfnSun's Avatar
St. Jude Donor '10
How long can the stock shortblock handle 12psi with its 11.5:1 comp ratio? Does that seem like a lot?
Old 06-14-2017, 03:29 PM
  #60
olblue75
olblue75's Avatar
Default Same Question
Would like to know the same. An does it suffer the same heat soak issues as the Z06??
Quick Reply: Z06 LT4 Supercharger installed on my 2015 Z51 Stingray!!
