C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Z06 LT4 Supercharger installed on my 2015 Z51 Stingray!!
Old 06-14-2017, 04:35 PM
  #61
managerman
managerman's Avatar
Originally Posted by SurfnSun
How long can the stock shortblock handle 12psi with its 11.5:1 comp ratio? Does that seem like a lot?
Good Question! Maybe The guys from Weapon X can answer that question. I am somewhat concerned about blowing out the front and/or rear seals due to the increased crankcase pressure. I recently purchased a Mighty Mouse Z06 Mild Breather/Catch Can that I plan to install soon. I know that will help with the crankcase ventilation. (and the oil ingestion into the blower)
I do not track the car and I am not hitting WOT very much, but I have hammered it a bunch of times at WOT and have had no issues....I have not had any heat soak issues at all...My IAT temps (which is IAT2 on a normal Z06) have been great. At 80-90 degree ambient temps and normal driving they are 115-135...With more aggressive driving I have only had temps hit 150 once...I love the setup and the custom tune on the engine and the trans. The car is so much more alive! The power is nuts!
-M
Old 06-14-2017, 04:39 PM
  #62
sales @ WXM
sales @ WXM's Avatar
Making around 600whp on the LT1 shortblock is not going to compromise the longevity of the engine life. The tune on Matt's (managerman's) car is very conservative as well. For example, we have seen C7/Camaro6 owners making 800whp on those for years now without missing a beat. That say a lot itself.
The weak point on the LT1's are the pistons. Keeping them cool with the proper fuel trims and timing is what makes them last. As long as the tune is safe, and the engine is not facing detonation, or anything that would cause overly excessive cylinder heat, (Which this applies to the stock LT1 as well.) I do not see it jeopardizing the piston/engine life at all.
Originally Posted by olblue75
Would like to know the same. An does it suffer the same heat soak issues as the Z06??
Yep, pretty much any PD type supercharger located in an intake valley is going to be subject to heat soak. It's just the nature of the beast. We do offer several products to combat that though.
Old 08-02-2017, 09:55 AM
  #63
managerman
managerman's Avatar
Update: It has now been over 5k miles since I had the install. No issues to report! Love this car!!
-M
The following 2 users liked this post by managerman:
1ccrider (12-04-2018), JerriVette (12-30-2017)
Old 08-02-2017, 10:28 AM
  #64
pj-c7
pj-c7's Avatar
Hi, I have a PD on my C7 and was curious what products you have to help with the heat soaking.
TIA,
Pj
Old 08-02-2017, 12:11 PM
  #65
sales @ WXM
TIA,
Pj
pm'd
Old 08-02-2017, 03:20 PM
  #66
DRB710
1st Gear
DRB710's Avatar
Default Z06 supercharger installation
Question - About the install how did you get around the Z51 motor having higher compression than the Z06? seems that would cause problems with cylinder pressures once the supercharger is installed. Also did you use the stock Z51 cam and how does that cam compare to the Z06 version?
Old 08-02-2017, 04:46 PM
  #67
T/A KID
T/A KID's Avatar
Compression is power... I run 12.1 in my car and over 12lbs... just have to understand how to do spark mainly...
The lt1 cam is larger on the intake (which makes power) and less on the exhaust (which aftermarket headers/etc alleviates the larger split the lt4 cam has)
Thats why this car stockish with lt4 blower made more power then an A8 z06
Old 08-03-2017, 10:14 PM
  #68
sales @ WXM
T/A KID I really couldn't have explained that better myself.
Old 11-12-2017, 10:47 AM
  #69
managerman
managerman's Avatar
Update: It has now been over 8k miles since I had the install. No issues to report! Just wish the warm weather was not going away so soon.
-M
Old 11-12-2017, 04:57 PM
  #70
9157
Naples FL
Support Corvetteforum!
9157's Avatar
Default Had mine installed this week!
-M
1500 miles and counting!
managerman (11-14-2017)
Old 11-12-2017, 10:43 PM
  #71
3 Z06ZR1
3 Z06ZR1's Avatar
Originally Posted by Drew27
Can you put the lt4 blower on a 17 Silverado 5.3 Eddie?
Absolutely.
That sounds like possibly a good place for my spare 1.7 coming off my Z06. On my 2015 5.3 Sierra!
Old 11-13-2017, 02:30 AM
  #72
Drew27
Drew27's Avatar
Eddie do you have a kit to retro fit that we can purchase?
Old 11-13-2017, 05:27 AM
  #73
Seannyc
Seannyc's Avatar
How does the car feel and what’s the dyno numbers
Old 11-13-2017, 10:14 AM
  #74
sales @ WXM
In order to fit the LT4 blower from Z06 on the 5.3 you would have to replace the snout with a ZL1 or V3 snout. You could fit the Z06 snout, but it would be quite a bit more expensive.
We still do not have the Silverado truck kit available. I can offer you the kit installed for the same price as the LT4 blower Stingray packages we have. Add $2000 to website price for the install/tune.
https://weaponxmotorsports.com/colle...nd-grand-sport
On a hot run after tuning it made 560whp/580tq.
Old 11-19-2017, 05:16 PM
  #75
Seannyc
Seannyc's Avatar
Can Anyone who has this set up tell us how does the car feel vs a z06 or show a video
Old 11-19-2017, 06:46 PM
  #76
9157
Naples FL
9157's Avatar
i had a '15 Z06 M7. This set up is instant power compared to the Z. A number of factors: this car is an A8 Vs M7. Different rear axel ratio: 2:41 vs 2:73 in the auto.
The cams are also different and compression also. All said and done, even thought the RWHP should be the same; this LT4 conversion is much faster and power is instant. All of my friends that have Z's that have driven it cannot believe how much more power it has compared to theirs when driving them back to back. Short runs it just destroys the z.
I could not be happier!
The following 2 users liked this post by 9157:
A320Flyer (01-30-2019), JerriVette (03-03-2018)
Old 11-19-2017, 09:09 PM
  #77
Seannyc
Seannyc's Avatar
thx for the reply good info to no
To Z06 LT4 Supercharger installed on my 2015 Z51 Stingray!!
Old 12-23-2017, 04:34 PM
  #78
onebad1lE
onebad1lE's Avatar
Bypass valve. Any pics of how to route it ?
Old 12-23-2017, 05:15 PM
  #79
managerman
managerman's Avatar
The only tube you have to connect is the one on the left (on the bypass valve) in the picture. It needs to be run to the port closest to the snout. It is shown in the picture as well. The port on the right is not used (I just have it capped) it is the one used by the electronic portion of the bypass valve, but the Stingray does not utilize it. You will also need to cap off the other port on the supercharger. It is the one farther back on the left. (Not shown)
Hope that helps.
-M
Old 12-23-2017, 08:17 PM
  #80
onebad1lE
onebad1lE's Avatar
i tried that and it didn't work
Quick Reply: Z06 LT4 Supercharger installed on my 2015 Z51 Stingray!!
