C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
FIC DI injectors in stock at CPR! 30% larger than lt4
Old 05-03-2017, 08:46 PM
Cordes Performance Racing
Supporting Vendor
Cordes Performance Racing's Avatar
Received 1,226 Likes on 773 Posts
Default FIC DI injectors in stock at CPR! 30% larger than lt4
I'm sure most of you have seen FIC's thread announcing the release of their 30% larger than lt4 injectors, we were one of the first to test these and helped develop the data needed to properly tune them. Through rigorous testing on vehicles we have a solid foundation on we have been able to help you the end user populate the needed tables to put these in and get them running right away! This service is offered only with purchase of the injectors through us for obvious reasons. We have tested these on e85 and on the gas scale to ensure 100% proper functioning and they flow the advertised amount. Combine these with the industry standard CPR low side fuel system for the ultimate in fueling solution for these cars. We have these in stock and ready to rock and are the only place that offers tuning support for these injectors to the end user.
Available for purchase here on our webstore.
http://cordesracing.mybigcommerce.co...434.1480354458
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old 05-03-2017, 08:52 PM
Drew27
Drew27's Avatar
Joe,
what power level will these mods support for 93 and e85?
Fic injectors
lpe hpfp
38% fuel cam lobe
cordes low side fuel system
Old 05-03-2017, 09:04 PM
Supporting Vendor
Originally Posted by Drew27
Joe,
Fic injectors
lpe hpfp
38% fuel cam lobe
no meth? auto or manual? blower or turbo car?
Old 05-03-2017, 10:06 PM
BooSSted
BooSSted's Avatar
How does this work , being octane dependant ?
For the sake of simplicity :
93 octane
No meth
Some say the stock fuel system is good to 670-700 whp.
So adding a 38% lobe, plus 30% injectors , if not octane limited (93) would this not be enough fuel to push 800-850 ? E85 isnt an option for many, so I guess at what point will alternate means be necessary for octane supplement with pump 93 maxed out?
Old 05-03-2017, 10:15 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
38% lobe and 30% injectors will support more than low side can. You will run out of octane and low side before injector in that case.
Old 05-03-2017, 10:18 PM
BooSSted
BooSSted's Avatar
At what levels will low side fp begin to fade?
Old 05-03-2017, 10:19 PM
Supporting Vendor
93 octane
No meth
no meth you can do easily 900 rwhp with it, but you'll be octane limited.
our low side will support what these can do, already maxed these out on e85 and our low side is still hanging in there, it's losing a few psi but the high side stays up so it's good. I could do the c6 gas tank conversion but screw that haha.
Old 05-03-2017, 10:22 PM
BooSSted
BooSSted's Avatar
So with the cam lobe and injectors 900 would be obtainable / octane limited? Or was your comment in regards to the two plus low side support ?
Old 05-03-2017, 10:26 PM
Supporting Vendor
for 900 rwhp you'll be octane limited so you'll need race gas or meth to hit it. You will need our low side system to support that too.
Drew27
Drew27's Avatar
Joe,
Fic injectors
lpe hpfp
38% fuel cam lobe
my bad...
f1x A8
with above mods..
I do have a dual meth on it but don't want to be dpendent on it
Old 05-03-2017, 10:33 PM
Supporting Vendor
my bad...
f1x A8
with above mods..
anytime you're spraying meth the tune has to be adjusted for the fueling. on pump/meth these injectors will support everything that f1x could ever do.
BooSSted (05-04-2017)
Old 05-04-2017, 09:17 AM
Earl H
Earl H's Avatar
Joe,
Fic injectors
lpe hpfp
38% fuel cam lobe
Not knocking any advancements in the DI fueling space. I applaud ANY advancements in a market that sorely needs development! If I look at your list:
FIC Injecors: $3,500
LPE HPFP: $1,500
38% Cam Change: $2,000 Incl labor, I am hearing more so could be short
Low Side Fuel System: $1,800
Total: $8,800
Note: this doesn't incl install on components other than the cam.
So we are close to $9K and I still have to run meth to get to 900rwhp whether its e85 (due to system capacity) or 93 octane gas (octane limits). Again, not crapping on this thread. I think any discussion is good discussion if the right intentions are there. I AM actively looking to do a Turbo setup on my 17 Z, so not just lurking...
Joe,
You guys were pioneers and 1st to offer a low side setup. Whats needed/cost to do a DI/Piggyback port injection setup on e85 that will support over 1,000rwhp? There are a few shops doing them.
Old 05-04-2017, 09:48 AM
Unreal
Unreal's Avatar
As much or more money, and complexity.
Still need low side to support it, need injectors, manifold, ecu, wiring, tuning, etc.
I'm not sure you need the LPE HPFP to hit 900 on e85. Injectors and cam lobe with enough low side should be plenty.
Joe, I was talking about the 30% injectors and 30% lobe would probably exceed the factory low side before you ran out of injector.
Old 05-04-2017, 09:58 AM
Earl H
Earl H's Avatar
In the interest of full disclosure. I have quotes for a port injection piggyback solution installed in house from a couple of well know shops for about the same money and as far as complexity goes...well its more in the integration and I think thats where each shop adds value. You are buying a low side to feed the low pressure injectors, injectors, standalone/piggyback controller and misc odds and ends. Again, not to derail the thread, but just generating fact based information in comparing options (not shops). I wanted to get Joe's take on a comparable port injection/piggyback system.
Old 05-04-2017, 03:08 PM
Onefst2004
Onefst2004's Avatar
WHY:. $437.00 each what are they gold plated. I heard of mark ups but really 437.00 each
JUST SAYING
Old 05-04-2017, 04:16 PM
Unreal
Unreal's Avatar
Then go buy the competing ones.
Old 05-04-2017, 04:24 PM
Onefst2004
Onefst2004's Avatar
Quess what you answered my question thanks
To FIC DI injectors in stock at CPR! 30% larger than lt4
Old 05-04-2017, 04:31 PM
Unreal
Unreal's Avatar
First to market can charge a premium until competition shows up. If your choice is expensive or nothing at all, it isn't much of a choice. I'm sure DI injector prices will come down over the next 2-5 years but right now the aftermarket ones are new, have a lot of R&D to recoop, and are the only players around, so you pay to play.
Old 05-04-2017, 04:37 PM
Onefst2004
Onefst2004's Avatar
I would rather have nothing then to pay 473.00 for an 200.00 if that injector. good luck.
Old 05-04-2017, 05:01 PM
Supporting Vendor
they are much more than a $200/ea when you factor cost into the injector before you even touch them. DI stuff has always been expensive, it's the same as diesel.
Quick Reply: FIC DI injectors in stock at CPR! 30% larger than lt4
