I thought I read somewhere, lash caps were bad?
I thought I read somewhere that lash caps were bad for the fuel pump in some what that wasn't expected. I could be completely wrong, but wanted to throw this out and see what i hook. Lt4, and fuel lobe cam increase of lets say 30%. What is the downside?
I'm Batman..
Pro Mechanic
https://www.corvetteforum.com/forums...learances.html
joemosfet (07-26-2017)
i used to think i was batman... but ill settle for second. You're just a plethora of knowledge on all my threads. Thank you buddy.
For me I know nothing about the mesaurments.
Installed the Pro charger and took the car for dyno with the tuner and the car wasn't getting fuel above 4K RPM
I was so frustrated the car did only 429 WHP with the supercharger installed.
The tuner called the shop and asked them to add the lash caps as they thought I don't need them.
They immediately Installed it I also did the Alky Meth since it was back to them.
The car then did Whp of 717, Now I have the second nozzel installed I don't know how much more if that will add but I'm much happier with the car now.
Just in case I'm looking now for the LT 4 fuel pup, injectors & rails I've been told they are a very good upgrade for the fueling system.
Which I'm searching for I couldn't find something that's reasonable as I'm reading more & more about it before pulling the trigger.
I would say it's been almost three months and no problem with the lashcaps.
I'm Batman..
Pro Mechanic
Installing a lash cap on the LT1 high-pressure fuel pump will not typically have any issues. If you move to the LT4 fuel system, the high-pressure fuel pump has a longer stroke and therefore you must use the correct thickness lash cap or you will blow the pump up. If the shop that you have do the fuel system upgrades to isn't aware of this specifically, take it somewhere else.
But if I upgrade to the lt4 fuel system, I dont need them i can just remove the lashcap and everything shoyld be fine???
I'm Batman..
Pro Mechanic
Wrong. Because you have a 32% fuel lobe and would also have an LT4 pump you need the lash cap to provide proper preload on the pump. But, it neads to be a thinner lash cap. They need to measure to see for sure how thin but likely its an 8MM x 0.060". NOT the 8MM x 0.080". That one is tooo thick.
