A&A Install for Everyday People
#62
Just use a large flathead to lock your flywheel. I will be doing a writeup on this as well. Not so much as a total writeup but some things i have observed and done differently. It was supposed to be here tomorrow but i got a text this morning it was out for delivery.....but being Fedex, they are probably wrong again even though i took off work today for it now....
#67
Christmas in August! BTW, where did you get your forged bottom end work done?
#68
The spec work was done by me. The balancing,parts check, cryo and maching was done by a small local shop here in Pasadena. The final layout, checkout and assembly was done by me as well.
#70
Thank you I used this and a couple other threads as guides.
I just finished my T trim A&A kit Dyno tune on the 24! final check and start up tomorrow.
Josh@AandASuperchargers (04-15-2019)
#74
Platinum Supporting Vendor
Try putting it in gear and set the parking brake. That might be enough to hold it from turning.
LuisZ51 (04-15-2019)
