C7 Z06-what pulley size for supercharger?
trying to increase the boost on the stock blower i already have a 15 % on the crank what size can u put on top on the supercharger with out over spinning the blower and over heating it ? who is running what ? i belive im at 10 to 10.5 psi max any input apresiated
Get your supercharger and snout ported. It will give you more bang for your buck and help you realize more benefit from your 15% pulley upgrade.
You could also step up to an 18% overdrive lower but I wouldn't recommend it based on what I've read. Alternatively you could add meth.
already have meth didnt want to go with 18% pulley since im planning on procharging and im using the 15% there i was trying to get couple more psi so i can get quick hp with out spending to much since it will all come off eventually
