How do I know if my clutch slipping
Hey guys,
My car has a forged internals and a 10 rib ysi setup cam, fuel bump and probably everything its need to make 1000whp on race fuel ,
The only problem im facing that the car drop power past 6300 rpm, do you guys clutch might slip at that rpm range on the dyno? Also on the streets its never get raced under 70 mph, and still drop power past 6300 rpm
That's not the clutch, it would be super jumpy and wavy. That is in the tune. Looks like an LS curve.
What RPM are we looking at though?
What smoothing factor is being used on that graph? As previous poster mentioned, clutch slip would cause a spike(s). A high smoothing factor could mask it.
Received 1,762 Likes
If you have a 416 build motor with a YSI & 10 rib set up that motor will make close to 1100 rwhp & 870 to low 900 RWTQ. Has to be in the tune..Robert
You have the boost curve? We could rule out belt slip, but with a 10 rib you shouldn't be slipping. Do you have a secondary fuel system on this car? What is your fueling setup? Meth I am assuming and what injectors and high pressure parts?
Fueling: cordes lower fuel system, zo6 hpfp and injectors, meth 15+10 nozzles, I don’t have a boost curve but i have a video showing the boost gauge if thats help pm me ur email
19 PSI on the YSI with what pulley? That sounds right on to me. That a *** ton of boost lol. What power did it make at 19psi?
Pulley setup is 2.7 and 8.35
Watching your video your meth isnt ***** out until 11psi. That seems WAAAAY too late IMO.
I think the car is fine. It just has room in the tune on the big end. The car was fat 10 ish A/F on the big end.
Man that's about spot on what my car makes at 14psi on pump gas but I run more timing.
I think the run i sent u was one of the couple first tuning runs, check the video I just sent u please
I think your issue is the tune. It's fat on the big end.
Yeh I know its boost reference but from where i can make it turn on earlier? I know the switch that have numbers from 1 to 8 isn’t gonna make it turn on earlier
