How many 8 Second 1/4 miles C7's are there?
It would be nice to have an updated fast list to see how fast some of the c7's are going now (not 1+ years ago). How many are in the 8.99 or lower? I am trying for a 8.99 on boost only here in a couple weeks. I went 9.1 last weekend with a slipping belt that was shredding apart. I'm hoping to be very close with my new belt. I met a guy in a blue base model at LSFest that was running 8.8's. I know of a white base that's around the same time as well and a Grey z06 (but haven't seen any updates recently). Any one know of other 8 second c7's besides those 3?
Received 1,296 Likes
2018 C7 of Year Finalist
And I know LMR and AMP both have 8-second cars. And I know of a blue one that popped up on my facebook like 2 weeks ago.
I'm on a 10rib now. 8.3 lower/ 2.75 upper. Belt seems to shred and come apart after a few months of driving. Just put a new belt on today. Hopefully I will get some updated times this weekend.
Hey dave, try the k100475rpm its should be better than the hd and gives more space
There are two as far as I know. AMP (Advanced Modern Performance) went 8.9 something. Then LMR went 8.8. LMR has the fastest C7.
Received 1,762 Likes
I know you may say yes it is but if a big rwhp car is just off a hair & running it really hard at the track it will start eating the belt up or if bad off will pull it off the pulley. Robert
bigsapper (11-24-2017)
Supporting Vendor
Congrats on a great running C7 man!
There are probably 4 to date that I can think of that have ran quicker than 8.99. We have built 2, a base white C7(Current record holder) and an orange C7 we built for a grudge racer that actually runs quicker but customer does not want any info posted online/forums/social media.
Its crazy to think we ran 9.3s at over 155mph a few months after the C7 was available to the public. Now almost 4 years later only a handful of cars have ran 8s.
From 2014
8 sec pass-
From 2014
8 sec pass-
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009
LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
713-466-9900
The following 2 users liked this post by Late Model Racecraft:
Dave01GT (11-07-2017),
LG Motorsports (01-13-2018)
Dave’s a friend of mine.. he will get that 8 second pass 👍🏻 And probably go faster!
Have another customer with not even a dialed in tune that’s going almost 160 I’m crap DA in a f1x c7 Z06... it’s a Manual, but if an auto, we be going for the record
Supporting Vendor
That is awesome! We need more of these cars pushing the limits. The 8sec car we built is only running an F1R head unit. I wish she had an F1X.
I've seen a couple CTS'V guys with the RPM belt, and they've been shredding very quickly. Even worse and much more quickly than the HD green belt. Have you had any experience with the RPM? I'm just going by what I've seen from 2 guys I know.
Dave why are you going thur belts for. I went thur 3 belts until I got the set up in the c5 laser lined up on the pulleys. Then never a problem again plus I had my 8 rib so dam tight on top of that.
Before the new belt my max was 18.5. With the new belt and bellmouth I saw 21. My 9.16 pass was fluctuating between 12-17psi with the slipping belt. Now that it's seeing 21psi, my intercooler is pretty insufficient and seeing IAT's over 170* at the 1/4
Didn’t try it, i even sent an email to david from supercharger online, he said they dont have them yet
It does almost look like my one tensioner is slightly off. You can see the belt wears more to one side and close to the edge. I took it off and flipped the metal race to the other side of the pulley, but then it hit the supercharger bracket. I assume everything is lined up how it should be, but does seem slightly off.
Best tool I have and use for this is the Dayco lazer alignment tool... works wonders as easy to use... has a sight line the lazer shoots down for alignment.. also had a tension setup to test belt tension (there is a entire science too it that most don’t understand)
I am with you on this. Plus also Dave if it looks a little off to your eye it has to be off a ton for it to be tuning those RPM & doing that to a good belt. After I got a laser & got mine fixed it never did do a belt again. I was at 24 & 25 lbs of boost with a F1X on the car. Robert
