C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
WEAPON-X "Boost Freeze" Chiller
Old 02-18-2018, 11:29 AM
Ben@WeaponX
Ben@WeaponX's Avatar
St. Jude Donor '14
Default WEAPON-X "Boost Freeze" Chiller
With a well known name for the best heat exchangers and ancillary cooling mods on the market, we have been working on the next step in cooling for the past year and a half and after testing various combinations, we are finally ready to release our Boost Freeze Chiller! We have developed a complete plug and play system allowing you to tie into your OEM air conditioning system! This is the very first chiller system even available for the gen 6 Camaros, C7 Corvettes, CTS V gen 3s, and the ATS V and we also have the previous gens covered too While this technology is not new, unfortunately to date, chiller kits have always been surrounded by mixed reviews from poorly designed kits with vastly incorrectly sized heat exchanger units, that required the OEM lines and wiring to be cut, brazed, welded, soldered, etc which means you needed someone that specializes in the AC field, and train-wreck forum threads between competing manufacturers bickering, accusations of them copying each other, and on and on. It was apparent that most of these guys were copying someone else's kit as in the end, a lot of consumers couldn't get their kits to work properly and received little support after, resulting in more bad PR for the chiller concept. However, simply put: the proven concept WORKS AMAZINGLY WELL when done properly! To prove this from a neutral source, the highly heralded Dodge Demon has a chiller from the factory, yes factory... we were shocked to see this!
How it works?
A chiller uses the OEM air conditioning system to reach freezing temperatures in the supercharger heat exchanger coolant to remove MORE heat from the compressed boosted air entering the engine, making it denser, allowing for MORE timing, and thus MORE POWER!!! (insert a Tim the Toolman AR AR AR ) Now a commonly understood principle is that the cars that run with the AC on lose lots of power during wide open throttle (WOT) for a few reasons, 1 the AMP draw is high, 2 it floods heat into the radiator from the AC hx, and 3 the older units wouldn't destroke themselves when they see this. AC compressors have continued to improve and the one on the LT cars is impressive. Most cars will shut the AC off during WOT for the aforementioned reasons; however, the new ones will actually reduce the stroke on them, not really consuming much power at all. In our testing on an 850whp LT4 Whipple car, we only observed about 20 LB FT of torque down low and and less than 10 WHP up top!
The Benefits
Our kit has a lot of bells and whistles as well and it's plug and play with custom billet fittings we machine in-house. The cabin air conditioning on our kit remains unaffected and still allows you to remain cool inside while your supercharger gets frost bitten too as it includes a cabin diverter valve so you can leave it in 50/50 mode splitting the AC, or put it into 100% HX mode so the supercharger coolant gets all of the BTU capacity to reduce the fluid temps even quicker. The kit also includes a thermostatically controlled valve that bypasses the heat exchanger(s) too because there comes a point when the coolant is below ambient temperature and running it through the aluminum heat exchanger will actually heat up the fluid. Lastly, we an optional have a Bluetooth display that you can adjust your temps and valve with while monitoring just how cold it gets. Consequently, our SPI Kit can also control the Chiller as well.
One of the most unique features of our kit is we have also developed a thermal cooling cell, which needs no ice or anything other than the top secret stuff inside of it LOL. It serves as two purposes, extra fluid capacity and extra BTU capacity. As the chilled fluid passes through it after the chiller, it charges the cell and once the fluid starts to heat up from the engine heat transfers that occur over the course of a run where the AC system is taxed by the external heat sources, the fluid is then chilled again by the cell as well to help with longer periods of time. This really helps the entire system, especially for in times of higher ambient air, longer runs, and other adverse conditions. A lot of guys have asked about the possibility of running this in road racing, and I didn't want to get into it before we had more product development; however, I do think it is possible on the LT cars. The main thing that is needed is to insulate all of the lines, fittings, etc and be able to keep the condensation off of the track. I am very interested in working with a road racer who is savvy when it comes to data logging and being able to provide the necessary data in return. The kit
System features:
  • Plug and Play hardware for a hassle free installation
  • 100% reversible
  • Requires no tuning changes; however, the PCM calibration can be modified to achieve more power when temps are under a certain threshold (IAT Advance)
  • Insulated chiller unit
  • OEM quality hardware, lines, and fittings
  • Thermostat controlled heat exchanger bypass when temperatures are below ambient
  • Cabin diverter for race mode to channel ALL of the refrigerant to the chiller
  • Bluetooth controller for Temperature monitor and custom programming settings
  • Thermal Cooling cell to store extra BTU capacity
  • Optional WXM Track Attack Heat Exchanger upgrade further more natural cooling
Example:
Here is an older version of our Chiller on my 1150whp Gen 6 ZL1. This car is a MONSTER making 1100lbft of torque by 4200 RPMs with an 85mm rear mount turbo pushing through the stock Eaton 1.7L LT4 ported supercharger. It has been an interesting project for sure, we are not spinning the blower crazily at all with a 25% increase, but it's making 14 PSI on the 427 cubic inch LT4 engine as we have MAP sensors at various positions on the kit to log. 14 PSI with only a 25% increase on a 427 with our big valve heads is amazing. All together, the compound boost was around 24 PSI. The air temps coming out of this air to water box with 14 PSI from the turbo, but only 10 PSI after running the length of the car and going through the air to water box was just 46* as it entered the supercharger! So, the more dense air entering the supercharger along with the pushing of that air from the turbo greatly reduced the parasitic loss of the supercharger making the entire system more efficient.
On a test hit I made, the Air Temp post supercharger lobes was 99* at 142 MPH and having gone through 7 gears (10 speed auto). That is astounding at that power level!!
The following 2 users liked this post by Ben@WeaponX:
Eat.Sleep.Race (02-18-2018), sonny615 (02-19-2018)
Old 02-18-2018, 08:22 PM
Eat.Sleep.Race
Eat.Sleep.Race's Avatar
Looks pretty amazing!
Old 02-18-2018, 08:25 PM
on3wego
on3wego's Avatar
Pricing, similar to a a2w system? Harder on the a.c. compressor?
More pics
Old 02-18-2018, 08:31 PM
Drew27
Drew27's Avatar
Awesome
No need to buy expansion tank or upgraded heat exchanger...
Need info for C7
Old 02-18-2018, 11:19 PM
FYREANT
I'm Batman..
Pro Mechanic
Support Corvetteforum!
FYREANT's Avatar
This is awesome! Will this work for supercharged c7’s that don’t have heat exchangers? (Non-z06)
Old 02-18-2018, 11:25 PM
KKC7
KKC7's Avatar
Originally Posted by fyreant
this is awesome! Will this work for supercharged c7’s that don’t have heat exchangers? (non-z06)
+1 🤔
Old 02-19-2018, 12:03 AM
Drew27
Drew27's Avatar
Should work on any setup that has air to water setup
Ben@WeaponX (02-19-2018)
Old 02-19-2018, 01:58 PM
Ben@WeaponX
St. Jude Donor '14
Correct, we will have a complete kit for air to air guys to convert over to ATW with the chiller and one of our WXM Track Attack heat exchangers in the Z06 baffle, with pump etc.
The space for an air to air IC is terrible on the C7s and we haven't tested them all, but Procharger has a 9lb pressure drop at 21psi in the manifold on the F1s we've tested!!!
Old 02-19-2018, 02:38 PM
FYREANT
I'm Batman..
Pro Mechanic
FYREANT's Avatar
This is awesome. Eager to see it! Where do you fuys mount the heat exchanger for us A2A guys? Since im on an A&A kit, I have my IC horizontal mounted.
Ant
Old 02-19-2018, 09:47 PM
on3wego
on3wego's Avatar
Curious on pricing...
Old 02-20-2018, 11:03 AM
Ben@WeaponX
St. Jude Donor '14
Ant
you have to delete the ATA IC and put the Z06 baffle in with our HX and an ATW box like on my ZL1
Since this is a rear mount turbo/supercharger setup though it won't be this complex
FYREANT (02-20-2018)
Old 02-20-2018, 11:58 AM
chuntington101
chuntington101's Avatar
This should be great for the drag racers / street pulls! Just need to make sure you tank is big enough so you don't get the water going through the intercooler several times per pull.
Ben, are you going to be supplying the a2w intercooler as well or will you be recommending using say the PC one? You also mention a HE, is there enoughndemand for a HE with this system? Is there any changes needed to the gassing of the stock AC system (other systems have needed this to be sucsessful)? Any plans to market for the stock blower / HB / Whipple cars as well?
Old 03-10-2018, 01:17 PM
sonny615
sonny615's Avatar
Looks very interesting , def might be able n the want list.
Old 03-11-2018, 04:41 PM
Ben@WeaponX
St. Jude Donor '14
Sorry I missed this. Capacity can be a double edged sword. Not enough and it's as you said above, too much and it will take too long to cool down after it's been heated up.
We'll be offering a complete kit to swap out from the undersized PC intercooler. On the F1X 427 C7 it's going on here, we're putting our popular Track Attack Z06 HX up front in the Z06 baffle, we have an air to water intercooler in the port injected manifold, and the chiller tying into it, and we're reducing the F1X blower RPM and going straight from the outlet of the blower into the manifold!
I can tell you that with 21psi on my compound boost ZL1, the water temps are in the 30s and the air across the MAF post chiller are 44*! Now, they go through the rotors after that and are compressed again; however, then they go through the same chilled water in our custom high boost intercooler bricks inside of the blower, and go back down
Old 04-16-2018, 02:22 AM
wwx8989
wwx8989's Avatar
Any news on this?
Old 04-22-2018, 01:15 PM
Ben@WeaponX
St. Jude Donor '14
Originally Posted by wwx8989
Any news on this?
Yes the first one is on one of our flagship builds, Storm's 427 F1X car and we ditched the Procharger FMIC and went with a custom manifold housing an internal Bell intercooler and is tied to the chiller and our WXM front mount HX that is used on the Z06s.
Car will be on the dyno this week!
From there, we're just waiting on a couple of tools left, and we will start the preorders while we're ramping up production!
Old 04-23-2018, 09:53 PM
BooSSted
BooSSted's Avatar
Let's see some pictures of this set up!! Very nice...
To WEAPON-X "Boost Freeze" Chiller
Old 04-24-2018, 06:30 AM
Doug18
Doug18's Avatar
Cant wait to learn more about this, it is a very interesting and innovative solution to a problem.
Old 04-29-2018, 05:35 PM
Corvette4ever
Corvette4ever's Avatar
Will this work with Magnuson Heartbeat kit?
Old 04-29-2018, 05:49 PM
Drew27
Drew27's Avatar
Should work with any setup with slight alteration
Quick Reply: WEAPON-X "Boost Freeze" Chiller
