My 2017 C7 base coupe 7mt procharger project
#41
Looks good are you waiting on tune or weather?
a lot of good diy blower installs going on and trying to decide, excited to hear how you like the car with Procharger!
#42
I kinda just squeezed my way in and dropped it on him.
So I am waiting for him to tune it, but I told him to take his time with it since the weather is garbage here anyway. The car is safe inside his shop so it makes no difference if its done tomorrow or in 3 weeks
#44
pretty sure that its an elite enginerring one. not sure what model. haven't seen it in person yet. it got delayed shipping so he just held it at his shop until i brought the car back for the tune
#46
yes and no... it wouldnt come off with a 4 ft breaker bar, it wouldnt come off with a 3/4" impact gun.
Finally we heated the **** out of it with setaline torch and hit it with the 3/4 " impact and it came loose. Rounded the fk out of it in the process but the kit comes with a new bolt anyway and if it didnt't I would recommend getting an APR Crank bolt
#47
For yours, I would shorten the line from the driver's side valve cover enough to make it run straight across to the fender or put a fitting on it to make it angle straight down and run towards the abs module.
Here is after I installed the FSP breather/catch can. I'll get a better angle later.
#48
Ehh... sorry to say but that routing looks pretty bad, at least to me. I routed mine like the manual said to do and it keep its below anything you need to access. Here is mine when I first installed it.
i need to clean it up more... but he did me a favor by fixing it as much as he did... it was real bad before. technically the car is only there for a dyno tune but hes a good guy and did what he could in what little spare time he had
#49
#52
yes ! hopefully by saturday night ill be able to pick it up. not sure when i can get down there. also want him to drive it around for a while make sure the drivability is all there
#53
he said a few more small tweaks and its ready for pickup. thats what is great about EFX tuning. they will not give you your car back until it is perfect, some tunes in the past i have seen car makes great numbers yet has 0 drivability.
Dave, Butch and their team make sure the car makes great numbers and retains as close as possible to stock drivability
#56
Okay so now here is my review of the procharger from install to tune and drivability
-install took me 8 hours
-Everything fits real well, nothing has to be hacked
-first startup car runs terrible, i mean terrible (untuned) I only had to move it out of my shop and onto my trailer (I had this planned though and was only putting it on my flatbed tow truck or my car trailer)
-my buddy tuned the car at his tuning/performance shop (i have a repair shop)
-picked the car up and WOW !
the car is extremely fast, probably going to be putting a drag radial on it because if you lay into it at any speed or gear it breaks loose (its also only about 50 degrees here currently)
retains stock drivability and idle until you lay into it
I didn't order my gauge pillar far enough in advance so right now have no boost gauge or AFR gauge so its kinda like driving blind
I would 100% do all these mods again, the car is so much fun to drive and sounds so nasty its insane !
So overall between the install, my #s and the drivability and power I would highly recommend the procharger !
#57
my custom 2 pod a-pillar gauge pod from ortiz custom pods is shipping out tomorrow very excited to install that along with my AEM AFR and digital boost gauge
also MT ET Street SS drag radials for my rear 285/35/19
#58
post some pics of your gauge pod. Also impressions of the ET Streets. Thanks!
#59
