Supercharger info
Supercharger info
Hello all,
Question about getting a A&A, ECS, basically a centri for a Grand Sport. If i install a cam in the car, do i still need meth injection on the car or will the extra fuel from the cam do the trick. Kinna wanna stay away from meth if i can. FYI, i would keep the car around 620 or so HP.
get meth, makes a big difference, i have A&A sc with meth and love it.When that light turns green under wot its almost like hitting N2O
Hello all,
At the power you are looking for I think you can do it without meth, cam should do it, but if you want to keep make sure it will work add the zo6 stuff on top of the cam,
I didn’t experience this before but it shouldn’t be a problem to run it with out meth and add the cam
Good luck
Good luck
if you got the money and are putting a CAM in you definitely should .. IMO.. port heads, get some VR drop in pistons and possibly rods. I did not do the rods myself sadly and im kicking myself for it.
Just in case you ever wanna turn it up... No reason to rip the whole engine apart for a cam only when you can probably get that horsepower without a cam.
Former Vendor
For 620rwhp on 93 fuel you will not need the methanol injection, but anything more than that you really need to consider either it or a LT4 HPFP/injectors and low-side upgrade. We just recently finished a C7 A8 car with a cam kit/headers/ECS 1500 with just the fuel lobe making 630rwhp on our dyno and no pressure issues what so ever.
- David @ Vengeance
- David @ Vengeance
Red Ryder (04-04-2018)
Former Vendor
You should still make close to your goal (depending on dyno/conditions/tune). It doesn't take a lot of boost to make that kind of power, so not a huge deal being on 91.
Former Vendor
