C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Main seals on LT1 question
Old 04-09-2018, 11:39 AM
Clifftrail
Clifftrail's Avatar
Default Main seals on LT1 question
I'm debating adding the E-Force to my LT1 Z51 but am a little concerned with various feedback about the front/rear main seals being blown out due to crankcase pressure.
My plan is only for the Stage 1 7.5 boost and already have a E2 catch can (closed) system on the car so not sure if this assists with the issue or is the vented system a must when adding FI?
There is obviously some risk involved with adding boost to a car not designed for it but is the risk very high for the base kit?
TIA.
Old 04-09-2018, 12:40 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
Man put a catch can onto the car I did a MMS can to me the best one out here. You can always pull the can if you had a problem & had to have war work. But was reading from someone in here the 2017 & 2018 have a better PCV system on them than the 2014 & 2015 & 2016. Robert
Clifftrail (04-09-2018)
Old 04-09-2018, 04:13 PM
Clifftrail
Clifftrail's Avatar
There are lots of folks that have gone FI on the LT1 here, is blowing out the front/rear main seal a rare event that is only occurring on high boost cars?
Or is it just the result of the new seals can't even take increased pressure from a base FI kit?
Old 04-09-2018, 08:00 PM
stab1991
stab1991's Avatar
Was a problem in the first cars that were boosted. Now the tuners have this figured out. Larger PCV hoses and proper routing and not running too much timing.
Old 04-09-2018, 09:53 PM
BlueDevilZ51
BlueDevilZ51's Avatar
I have the stage 2 E force with 9 lbs of boost, I also have the Elite E2 catch can. I haven't had any issues.
I think the seals failing are on cars running more boost.
The following 2 users liked this post by BlueDevilZ51:
Clifftrail (04-09-2018), pj-c7 (04-10-2018)
Old 04-09-2018, 11:30 PM
Clifftrail
Clifftrail's Avatar
Thank you for the feedback.
Old 04-10-2018, 01:43 AM
onebad1lE
onebad1lE's Avatar
Just blew my front seal 12lbs. And high timing and no venting
Fixed it and added venting and lowered timing back down
Old 04-10-2018, 12:14 PM
robert miller
The seal in the c7 is crap all the shop's are putting in the ls7 seal I believe to help with this problem. But for sure in a boosted car you need a catch can to help get pressure from the bottom.. Robert
Old 04-10-2018, 02:47 PM
Clifftrail
Clifftrail's Avatar
Are you saying the seals in the LT4 are the same? Do they have a different crankcase vent system to compensate?
Old 04-10-2018, 03:14 PM
blue_bomber697
blue_bomber697's Avatar
Received 1,296 Likes on 479 Posts
2018 C7 of Year Finalist
830whp on a built 416 motor. Pushing about 12 lbs of boost and haven't had any issues with the seals yet. I do not have a catch can or any additional venting. Car goes WOT a decent amount and things have been holding strong. Mines a '14 Z51.
Old 04-10-2018, 03:25 PM
robert miller
you have a TSP 416 motor correct. Seals are the ls7 PUSH THAT PUPPY UP TO OVER 18 lets see what happens.
Old 04-10-2018, 11:01 PM
blue_bomber697
LPE416. And I'm at the max power the car is going to see under my ownership. Not going to get a bigger blower unfortunately.
Old 04-11-2018, 07:18 PM
robert miller
Smart man I only have a A/A TI unit I will not go any more than this in the car. If it blows I will be doing stock bore maybe 5,k over piston with all forged insides small cam & calling that a day in the car. Robert
Old 04-11-2018, 08:14 PM
onebad1lE
onebad1lE's Avatar
Default Was front seal
Well fixed it and front seal —all messed up ,lowered timing back down boy does it run good with more timing I will miss that lol
And seems to run fine now also vent front two valve covers
Old 04-18-2018, 03:02 PM
bc928
bc928's Avatar
If timing is affecting the blow by, which causes the seals to blow out, then that means the cars are detonating.
A non-detonating piston does not have as much ring flutter and will not let nearly as much pressure by.
In fact I have held the single crankcase vent pipe from an engine at load at 6k when there was no detonation and it was not more than minute breeze of air.
I would hazard a guess that with e85 there will be less blow by at the same timing as with pump gas. Unless someone got stupid with timing.
Old 04-18-2018, 04:09 PM
C7&7
C7&7's Avatar
Exactly....
Early on people were popping front seals left and right because tuners were approaching the LT platform like the LS platform...with gobs of timing. Too much timing will get you in trouble in a hurry with the LT platform. The same reason breather systems hit the market as well.
Old 04-19-2018, 01:34 AM
bc928
bc928's Avatar
The Ls was taking more timing? The ls has lower static and dynamic compression. **** I think the stock lt1is pinging on 91 octane at 85 degrees ambient.
To Main seals on LT1 question
Old 04-19-2018, 04:27 PM
FYREANT
I'm Batman..
Pro Mechanic
Support Corvetteforum!
FYREANT's Avatar
That ping you hear may likely be the direct injection “tick” and is actually normal..
Old 04-19-2018, 08:45 PM
robert miller
To the guy above if it is what you are thinking, something is bad wrong with your car. Robert
Old 04-26-2018, 01:33 PM
TorchZ51
TorchZ51's Avatar
Originally Posted by C7&7
Exactly....
Actually according to LSX magazine, the LT can handle a leaner fuel mixture and more timing than the LS motor.
Quick Reply: Main seals on LT1 question
