Again, will Toyo R888R's work on a boosted Vette??
badass1g, I'll bet you that's a 295/30/19 because it's not available in that size in a 20.. I wish someone would speak up on running a R888R in 315/30/20 without rubbing.. I just can't spend $800 Plus on two tires that will rub.. Looks like I'm going to try some 285/30/20 R888R's on some 20x11 XO Verona's..
https://www.jegs.com/webapp/wcs/stor...3AOrderItemAdd
They say they are coming out the end of may or first of June, I would wait if you possibly can. They should def work better then the 888. IMO.
badass1g, You can't run run-flats on the front when you run drag radials on the back.. I want the Vette to still handle like it's on rails..
AWWWW I see, that makes sense now. Well please post back here when you get them on and let me know how it goes. So if I have non run flats up front, I would be ok with the ET streets on the back right? Just wouldn't want to push it in the corners too crazy right?
2FAST4U (08-07-2018)
#33
#34
#37
Curious here too. Summit shows the MTs are available for the Z51s but I haven't tried to order them yet so not sure. Im gonna try to keep my run flats up front with the MTs. She's not my daily driver so as long as it's not terrifying to drive I'll leave them on. I'm still 2 months away from my sc install tho
#38
Below is the difference between the base Z51 wheel setup and what you want to do with the 20x11 Verona’s. Appears to be slightly more than a half inch bigger in diameter. We know 305s definitely fit 20x11 wheels with correct offset. Probably a good chance 315 fit too, but they are slightly taller that the 305s.
285/30-20 315/30-20 DifferenceDiameter inches (mm)26.73 (679)27.44 (697)0.71 (18) 2.7%Width inches (mm)11.22 (285)12.4 (315)1.18 (30) 10.5%Circum. inches (mm)83.98 (2133.14)86.21 (2189.69)2.23 (56.55) 2.7%Sidewall Height inches (mm)3.37 (85.5)3.72 (94.5)0.35 (9) 10.5%Revolutions per mile (km)754.45 (468.79)734.96 (456.68)-19.48 (-12.11) -2.6%
John Micheal Henry (10-24-2018)
