C7 Vendor for Sale Exclusive forum for vendors to list C7 products, services and promotions.
Fuel injector connection high flow injectors on sale at juiced motorsports!!
Old 05-11-2018, 12:28 AM
0JUICED1
Former Vendor
JUICED1's Avatar
Default Fuel injector connection high flow injectors on sale at juiced motorsports!!
Fuel Injector Connection is your leader in direct injection fuel injectors.
Each set is 100% flow matched using the latest digital flow meter system. The injectors in your set will have identical flow and dead-time characteristics. With your purchase of fuel injector connection signature series stet, you will receive tune data to assist your tuner, 2 complimentary service certificates (value of $350) and lifetime warranty to original owner.
Check out the stock LT4 injectors (a great upgrade for LT1 cars) or the GDI high flow injectors for big power applications. Priced right at Juiced.
12682374 - LT4 injectors (set of 8)
FICGDI - Gen V GDI High Flow DI Injectors
Old 05-11-2018, 11:43 AM
jerho
jerho's Avatar
Will it need a retune? Approx how much of an hp increase can I expect.
Old 05-11-2018, 08:30 PM
0JUICED1
Former Vendor
JUICED1's Avatar
These injectors have seen over 1k rwhp. Yes, always tune after an injector swap.
Old 05-13-2018, 03:35 PM
0JUICED1
Former Vendor
JUICED1's Avatar
If you want to run E85 you'll need some fuel system upgrades
Old 05-14-2018, 11:16 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Ready to add some big power to that C7. We'll beat any deal on these injectors
Old 05-17-2018, 12:11 AM
0JUICED1
Former Vendor
JUICED1's Avatar
Wanna run past 1000rwhp
Old 05-19-2018, 02:43 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Fuel Injectors Connections DI injectors can handle 4 digit power levels
Old 05-22-2018, 09:41 PM
0JUICED1
Former Vendor
JUICED1's Avatar
We'll beat any deal on these. Major upgrade for DI cars
Old 05-23-2018, 04:48 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Big time injector upgrade for boosted applications
Old 05-24-2018, 04:58 PM
C5-VERT
Support Corvetteforum!
C5-VERT's Avatar
Cruise-In IV Veteran
Low side fuel upgrade + larger DI injectors + tune OR Low side fuel upgrade + port injection system? Seems price from what I am finding is similar or within range. Port injection clearly is more moving parts but if goal is around 1000 rwhp on M7 thoughts?
Old 05-24-2018, 09:57 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Honestly? What ever your tuner is more comfortable with.
Old 05-25-2018, 04:25 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Fic
Old 05-27-2018, 03:07 PM
0JUICED1
Former Vendor
JUICED1's Avatar
FIC systems in stock. We can ship these anywhere for free or we can install and tune your car.
Old 05-27-2018, 03:25 PM
C5-VERT
C5-VERT's Avatar
Wouldn't you need a low + high fuel upgrade + cam with increased fuel lobe to allow these to reach 1000+rwhp? Guess I am on the fence of going this path or a Direct Port Injection system which would most likely get me well past 1000rwhp. 1k is my future goal nothing more which is why I am stuck which is the cleanest path. Vengence is close to me and I plan on letting them tune if I went this route. One issue I see is the cam install that's $4-5k alone. Since these flow 30% more assuming that is on stock cam fuel lobe? Curious why GM didn't just use larger injectors on the ZR1? Thanks for your help.
Old 05-27-2018, 03:56 PM
0JUICED1
Former Vendor
JUICED1's Avatar
You would need a low side and high side to break 1000hp. This would be the easier then running the secondary set of injectors IMO but maybe a bit more expensive. I was shocked to see GM go with the secondary set of injectors as well. I'm guessing the R&D didn't get the bigger injectors and high side pump ready in time.
Old 05-29-2018, 09:35 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Let's mod that C7
Old 05-30-2018, 10:03 PM
0JUICED1
Former Vendor
JUICED1's Avatar
We have everything from basic mods to serious race stuff
To Fuel injector connection high flow injectors on sale at juiced motorsports!!
Old 06-01-2018, 09:46 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Fic
Old 06-02-2018, 06:42 PM
0JUICED1
Former Vendor
JUICED1's Avatar
These have supported E85 at over 1000rwhp
Old 06-04-2018, 10:28 PM
0JUICED1
Former Vendor
JUICED1's Avatar
We have all your fueling systems covered.
Quick Reply: Fuel injector connection high flow injectors on sale at juiced motorsports!!
