Stock LT1 Injectors/Fuel System for Supercharged Motors?
Moderator
Received 3,061 Likes
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '08-'12, '14-'15
I have asked 3 different tuners this question and have received 3 different answers, so maybe the answer is not that clear cut. That said I know many of you have done this mod before so what is the concensous.
I have a 2017 GS with Intake, 1 7/8 AR Headers, X Pipe, Hi Flow cats. Looking to keep it streetable. Do not want to run Meth or Fuel Additives. Goal is 590-620rwhp
Looking at Either a Procharger D1x or ECS Novi 1500.
Question is...will the Stock LT1 Fuel System and Injectors handle this upgrade without any problem?
Dig
Moderator
Cruise-In V Veteran
Thank you for the reply. Question, is that more of a safety precaution or has your tuner advised you of this? The reason I ask...one tuner said no problem at all...another said that would not even install it without an LT4 Injector upgrade.
I'm Batman..
Pro Mechanic
What are the odds that 575 will keep you happy? Doubtful. Thats where the LT1 system is going to top out and I think that may be a lil generous. As in at that point its probably not to safe to go any higher. Why don’t you want to do injectors and a high pressure fuel pump? Now is the right time to do it. Get it done and be on your way..
Dig
Received 1,762 Likes
I got 55 gal drum of it now so going to use it up & then may look at something else like LT4 inj & pump also. Bump with a stock short block will hold it with the meth to just under 700 rwhp with a A/A TI & 3.4 pulley for now.. Robert
If & when my motor goes this will be what I do & drop the meth for sure.Robert
Upgrading that setup to have a supercharger, you should increase you fueling without meth. At 600whp, you probably will run out of injector. And even if you can just barely scrape by, I wouldn't want to be at the max limit of my injectors all the time.
Install just the LT4 hpfp. You don't need the injectors. I just did the same upgrade and my lt4 pump supplies plenty of fuel, and didn't require a lash cap either.
