Few shots around the shop
Supporting Vendor
Our photo guy who films all our weekly episodes (link below)
https://www.youtube.com/user/joeazhp/videos
took a few shots of some of the cars we are currently working on in the shop. These are just a few, always many more cool things going on but some stuff we can't post
If you're looking for a shop that can turn out a build from simple bolt on's to wild high hp setups that stand the test of time and drive as good as they look, than contact us to discuss your build! We are not an internet smoke and mirrors shop, our packages run and run hard and drive exceptionally well and our attention to detail in the engine bay is world class.
Our Tuner Nic d's C6z he picked up getting an LME longblock in preparation for the f1x & power glide. motor is an LME 427 using an LSR aluminum block, mast heads, lme manifold, solid roller, etc. This is the stock engine coming out.
Zl1 1le in for one of our 1100 rwhp packages. CPR spec cam, LME heads, procharger f1a94 10 rib a2w kit, meth, cpr low side and high side, monster triple clutch, cpr valve covers, cpr dod delete plate, arh headers
6th gen ss we finished up with a 416, lme heads, cpr spec cam, cpr low side and high side, circle d converter, meth kit, procharger f1a, kooks longtubes w/ blackheart cat-back. this car made 930/840
Another 6th gen ss camaro getting a built motor, cpr spec cam, lme heads, circle d converter, cpr low and high side, 15'' conversion, driveshaft, axles, hellion twin turbo kit with precision 6266 bb, meth kit, flex fuel. goal is 1000'ish rwhp
Twin turbo trans am build that came in all stock. Built motor, th400, 9'' rear, all midwest chasis suspension, 8.5 cert cage, twin garret gtx35rs, air to water setup, etc, etc, etc.
Mark's grandsport we finished up that made 1009 rwhp. built motor, ported heads, cpr spec cam, cpr low side/high side, flex fuel, meth kit, circle d converter, procharger f1a94 w/ cpr custom a2w system, prospeed fan kit and oil cooler, dss axles, 17'' welds with skinnies, rpm roll bar 6 pt.
cool lineup shot. silver c7z is silver yeti that made 1200 rwhp on full e85 no meth before https://www.corvetteforum.com/forums...-the-dyno.html
back to fix a weld that broke on prochargers a2w tank they make, install a 8.5 cert cage, do a trunk mounted ice tank, and a few other goodies. Middle white c7 is the first one we ever built https://www.corvetteforum.com/forums...ottom-end.html
and it's still alive on the stock engine!!! 25k miles on the build and has done multiple half mile events, street racing, and drag events. It's now back for what will be our ultimate LTX build. sleeved ltx to a 427, all billet internals, solid roller, high rpm, f1x, custom a2w, nitrous, rpm level 7 c7z trans, rps clutch, axles, 15'' conversion, lme manifold, port injection, cage, etc, etc, etc.
Grandsport is marks I posted above, white mustang got a 600 rwhp package from us, and next to it is the zl1 1le i posted above.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
