Anyone lose their launch control after supercharger install and tune? - CorvetteForum - Chevrolet Corvette Forum Discussion
Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C7 Corvette > C7 Forced Induction/Nitrous
Reload this Page >
C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Old 05-28-2018, 09:11 PM
Comebackid
CF Senior Member
Default Anyone lose their launch control after supercharger install and tune?
Fellas,
I recently had a shop install an A & A Supercharger with tune (HP Tuners nguage). I've always done launches in Track mode in the past, but this time after the install, no dice.
In addition, I recently had the MSRC update done just prior to the supercharger install and tune. I ended up losing the MSRC update as well. Apparently on the first go around on the tune, everything was reset. The tuner informed me to have the MSRC update reinstalled at the dealer and everything should work. So I did. The good news is I got my MSRC update back, but still no launch control.
I've read past threads of others losing launch control after having the supercharger install and tune, but I would hear theories that with the car having much more power, launch control is incapable of holding the car down. It got me thinking. My setup is basic. No meth, no x-pipe, nothing. Just the supercharger. With that being said, my setup falls just short of Z06 power, and I'm sure the Z06 has launch control.
Can anyone offer insight and/or similar experiences and how it was rectified?
Thanks.
Comebackid is offline
Old 05-28-2018, 10:47 PM
BlueDevilZ51
CF Senior Member
BlueDevilZ51's Avatar
I have a stage 2 E force and still have launch control.
BlueDevilZ51 is offline
The Following User Says Thank You to BlueDevilZ51 For This Useful Post:
Comebackid (05-29-2018)
Old 06-05-2018, 09:26 AM
mustang00066
CF Member
Mine is gone and I was bothered after I found out. ECS meth and Headers The 4 cyl mode is gone too but that doesn't bother me much.
I wish there was someone that had a way to bring launch control back without reverting to stock. I smoked a hellcat yesterday though so I'm not doing too bad without it I guess.
mustang00066 is offline
The Following User Says Thank You to mustang00066 For This Useful Post:
Comebackid (06-08-2018)
Old 06-08-2018, 12:45 PM
Comebackid
CF Senior Member
That seems to be the consensus. What a disappointment. I loved that feature.
Anyone have thoughts on optimal traction at launch - settings, RPM, etc.?
Old 06-09-2018, 03:14 PM
robert miller
CF Senior Member
robert miller's Avatar
Start out at about 2200 rpm & go from that if the car goes on it face raise the rpm up about 200 more rpm until get gets out of the hole without braking loose. Then just play on getting into the paddle as it goes. Each car is a little diff even with the same parts in it so just getting a good amount of seat time in your car..
robert miller is offline
The Following User Says Thank You to robert miller For This Useful Post:
Comebackid (06-09-2018)
Old 07-09-2018, 07:35 PM
prince8619
CF Senior Member
prince8619's Avatar
is yours an auto or manual transmission?
prince8619 is offline
Old 07-09-2018, 08:12 PM
BlueDevilZ51
CF Senior Member
auto
Old 07-09-2018, 08:14 PM
prince8619
CF Senior Member
prince8619's Avatar
auto
What wheel HP are u at? And does ur car move or roll forward when u engaged the launch control from all the additional torque and HP?
Old 07-10-2018, 06:49 AM
BlueDevilZ51
CF Senior Member
I would think if youre car is moving or rolling forward when trying to use the LC, youre not pressing the brake hard enough.
Old 07-10-2018, 07:52 AM
Higgs Boson
CF Senior Member
Higgs Boson's Avatar
they probably tuned it out without realizing it. just let them know, no big deal. they can fix it.
Higgs Boson is offline
Old 07-10-2018, 08:59 AM
prince8619
CF Senior Member
prince8619's Avatar
that's what I thought as well. I am literally all on it to the floor with all my weight lol. I mean I have used it before when it was stock and I know what needs to happen, I am very family with the procedure..its just not happening in D mode or 1st gear. It's only works in 2nd gear.
Old 07-10-2018, 09:01 AM
prince8619
CF Senior Member
prince8619's Avatar
I did call my tuner..he said he never went into the launch control files, he was very surprised. Since you have a really high HP build, even tho its manual..does ur launch still engage in first gear? I think u did tell me u manually launch it since u get better times.
Old 07-12-2018, 05:17 PM
[email protected]
Supporting Vendor
Billy@MTI's Avatar
We don't even use it. Our cars will 1.3 60ft off the foot brake.
Billy@MTI is offline
Old 07-12-2018, 05:18 PM
prince8619
CF Senior Member
prince8619's Avatar
can you explain? So just floor it off idle? Cuz I did launch it manually at 1400rpm and let the brake go and it was like a rocket
Old 07-12-2018, 06:36 PM
badass1g
CF Senior Member
I have AA SC kit and They tuned it with HP and I still have launch control M7, however I tried to use my no lift shift a couple times and it doesn't appear to be functioning. Surprisingly when I called AA they seemed to have no idea about no lift shift. For how Vette savy they are I was surprised that they didn't know anything about it. I don't see why any auto cars would or could use a high rpm to launch (4k rpm). I wouldlnt think auto cars would need anything but brake and gas.
badass1g is offline
Old 07-12-2018, 08:08 PM
prince8619
CF Senior Member
prince8619's Avatar
On m7 manual corvettes, the rpms are much higher during launch control. On the A6 and A8, since its automatic..the torque converter multiplies the torque and the launch is typically 1800-2100 rpm and they launch with much lower rpms. When I used to use launch control in the past, I place the shifter in D, engage the launch control..my rpms stabilize at around 2000 and i let the brake go.
Now every since my car has been modified..the only way to keep the rpms stable is in Manual paddle shift mode and 2nd gear. First gear and D mode, the car just rolls forward and the rpms wont stabilize..meaning launch control cant engage. I am assuming, since their is so much more torque and HP now than before..the computer cannot control it and it can make stabilize the rpms for a proper launch.
Old 07-12-2018, 11:36 PM
ChiefP
CF Senior Member
Support Corvetteforum!
I have an A6 and my launch control still functions...but it's useless. It launched substantially better before the upgrades. Now it launches like a dog. I'm much better without it and just rolling into the throttle.
ChiefP is offline
Old 07-12-2018, 11:38 PM
prince8619
CF Senior Member
prince8619's Avatar
that's what I plan on doing the old school way. Thanks
Old 07-13-2018, 01:58 AM
chuntington101
CF Senior Member
I can't see how any launch control is going to work after mods. The torque curves will have changed so much that the pre programmed launch rpm, throttle input, timing, etc would be out by a mile! You would probably need to 'tune' the launch control for the new torque curve.
chuntington101 is offline
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
