A&A YSI oil return line install - oil level on WET sump LT1?
I'm Batman..
Pro Mechanic
Does anyone know where the oil level sits inside the oil pan on a wet sump LT1 when filled with the appropriate amount of oil? Im going to be tapping the pan while its still on the car and need to make sure the return line is higher than the oil level but I don’t know where the level is by default..
Received 1,762 Likes
ttt
I know you may think I am being a smart azz ANT but in my c5 I did mine as high in the pan as I could go on it. It work fine just use vasoline on the tap then chged the oil. I did it on the pass/side to the front of the pan. Robert
I'm Batman..
Pro Mechanic
I think you have my email and IG already but I’ll send it
Thats the plan.. lol
Thanks, I actually have a couple photos from A&A for the install (surprisingly the height of where its tapped is not the same in the photos of the two installs though. Thats one of the reasons for my question as to where the oil level is. Also oil level will be totally different on a wet sump I believe.
Lol I remember i sent you an email before but couldn’t remember which one was your email, already sent you the pictures
I did my ysi line in the front for my c5 (stock batwing oil pan), did you do the same pace?
I used the other oil pan & did it on the pass/side was better for me with all the intercooler piping. & with the drain line coming down from the YSI that was mounted on the pass/side also..Robert
