My LT4 Supercharger on my LT1 Broke? I am sick!
Hi just wanted to add my 2cents. I just had a LT4SC put on my Lt1 16 Stingray and purchased all the parts that I thought were needed, including the belt. Turns out I bought the Z06 belt and needed it to be a little longer since the shop had to use the adapter plates for the LT4 SC. Anyway, the shop called and said the belt was to short so I had to purchase a longer belt. Maybe the belt that was put on was the Z06 belt that is to short and it ran until it had enough got hot and shredded? Just a thought that's all. Good luck with recovery.
I would also get the Mighty Mouse Catch can with under blower valve to stop the oil. You can see it all over under your bonnet this oil and gunk kills your intercoolers over time.
glad to hear things worked out... did you have metal get into your engine? I assume you drained your engine oil and inspected the chambers with one of those snake cameras?
What was the cause, spinning the blower too fast, or was it a used blower?
Nothing got down below, and changed oil several times with no debris. It could of been heat issue, was a used one nobody seems to know for sure. Something could of gotten into the intake, just not sure. I am pretty cautious now and have a diablo hooked up to watch AIT and so on. Also, added the catch can.
