Going to install the Mighty Mouse Wild Catch Can - Anyone have pictures
I believe the kit came with some detailed pictures but like all upgrades real life experience always helps. Heck my A&A instructions were legit but simple things like what pulley worked for others on the balance were a life saver. I am going to put on my catch can tonight and hoped I could get some details from you. Thanks for the replies.
Well my friend. I am HOPING it really was as simple as I think for boosted applications. One line clearly went from the valley port to the can which I am very pleased with. I love A&A but my ONLY complaint is how tacky that setup looked with boosted applications, now its clean and all this is worth the work.
NOW HERES THE CONCERN. I believe the other port goes to my charge tube. My charge tube has a 5/8" line that went to the valley port. Well the line from the A&A charge tube is 5/8" and the barb fitting from the MM can is 3/8". SO obviously I need a new barb fitting but in the short term since my car is going in tomorrow for headers a "jerry" rigged it and put the 3/8" hose on for about 3" I then forced the 5/8" hose over it and used a clamp. It is snug and I am 99% confident it wont leak but I know I did that so I want the right fitting. Anyways I really hope it was that easy. If so I am disappointed someone wanted 2 hours labor to install. It took me 30 min and I was looking at pictures here, at the MM site, and pictures a buddy sent. Because I am boosted I wanted to be sure I was doing right for my application. I did NOT block off the PVC return.
Supporting Vendor
hi. these are the instructions for that kit
https://docs.google.com/document/d/1...JlIEP9pzIB3YH4
the pcv exit of the catch can goes to the intake manifold vacuum port, no exceptions if you want it to work correctly.
the passenger side v/c or oil tank will connect to the drilled open port in the air filter pipe, or connect it to the now available (larger) port on it that previously went to the passenger side.
Received 1,762 Likes
