I have this system i bought from MTI a few weeks ago, talk about great customer service from Billy and the whole team there. This system is very easy to install, good quality parts and again great customer service.
Thanks again for choosing us!! Happy to be of service.
Thanks,
Billy
I like it. I suppose the stock fuel lines can handle the additional pressure? Assuming it wouldn't have enough to run a port injection setup in parallel?
So far we know that the OEM line will support 860 wheel no problem. For the port guys this won't be enough. But we can build a port fuel system kit very easy with our controller.
Thanks,
Billy
This method of boosting low side does work... i been using similar dsxtuning setup on my c7 for a while now... it works great...
Well we all know boosting the high pressure side with a aux pump works but we haven’t seen many (if any) T into the high pressure line at the rear of the car and use the factory high pressure lines.
Sorry I did not specify... I have a T in rear of the car. Had to remove driver side muffler and pipe to get up to factory quick connect... I think i ran about 3-4ft of hose for the whole thing..
On our kit, Its all done in the drivers rear inner fender. You don't have to remove the exhaust on this kit.
Thanks,
Billy
Give me a call, Its sometimes hard to understand what is going on with a DI fuel system. I will explain everything.
Thanks,
Billy 832 945 1000
Just received the fuel pump controller artwork. The controller has a test button on it as well. We thought this was important for two reasons.
1. Once the kit is installed the customer can activate the pump and prime the system to make sure all the fittings are tight with any leaks. ( The kit will come with the hoses already made. )
2. Piece of mind. The customer can as he or she see fit test the system as they feel.
