We are just about ready to release our C7 Aux Fuel pump kit. Super easy to install. Takes about 3 hours and comes if everything you will need to do a OEM install. It will come with a wire harness and controller and won't break the bank. No need to drop the tank either. Just finished all the controller testing today.
Thanks,
Billy
Thanks,
Billy
All the components are in and we just finalized the wiring harness. We greatly appreciate you guys being patience with us. This is a pretty big project to take on. I should have the preordered kit done by Tues.
Thanks guys,
Billy
Thanks guys,
Billy
Looking good so far! Are you tapping power directly from the battery or are you using a switched source? Reason I ask is if you are using a switched source in the rear fusebox for the auxillary cigarette lighter outlets, many of us have tapped into that circuit for multiple things already and I would worry about it getting overloaded. Kits really are starting to look great though!!
We use main battery power and key one power to power just the relay. We tested our system with the Alky control system as well. No problem with powering mult relays at all.
Billy
Billy
