C7Z 700+whp Package: HPA Cam package w/ Extras, On Sale!
Former Vendor
Awesome numbers being put down with our HPA Cam Package. The IW Pulley and ALKY meth. injection added on take this cam package even further. Over 720whp and even more torque! Cam used here is our LT2.5 Cam.
This setup cost: $7,490
Includes:
- AFE Intake
- Corsa X- Pipe
- IW Lower Pulley
- ALKY Meth.
- HPA Camshaft package
- HPA LT2.5 custom camshaft
-+32-38% fuel lobe
-HPA AFM delete
-Comp Phaser limiter kit
-Dual .660" Platinum valve spring kit w/lightweight titanium retainers
-7.850 Hardened 5/16 .080 pushrods
-LS7 lifter set
-LS7 lifter buckets
-LT4 headbolt set
-Remove & Reinstall cylinder heads
-GM LT4 headgaskets
-NGK LTR7IX-11 Spark Plugs
-GM front crank seal
-Water pump gaskets
-Synthetic oil change
-Misc fliuds and solvents
-Professional installation
-Custom Tuning w/printouts
Our HPA Z06 Cam Package (LT2.5), without the add-ons, put down on average 630-640whp. Great cost to gain ratio for the pulley and methanol.
Standard C7 Z06 HPA Cam Package (as listed above): $4,200
Looking for power, but less invasive?
Bolt-On Package $3,499
Includes:
- AFE Intake
- Corsa X- Pipe
- IW Lower Pulley
- ALKY Meth.
-+32-38% fuel lobe
-HPA AFM delete
-LS7 lifter set
-LS7 lifter buckets
-LT4 headbolt set
-GM LT4 headgaskets
-Water pump gaskets
Former Vendor
Supporting fuel mods are needed for those amounts of E.
On 93 pump gas, moderate/safe timing, ~630s. Torque is even higher with these setups. Makes the cars move.
Former Vendor
Former Vendor
Sale still current!
Former Vendor
Get in on this setup! Outstanding cost to gain ratio.
Former Vendor
Another solid example of this package:
Talk details with us if you want to customize or adapt this setup.
Former Vendor
These cars are fast with this hp and torque curve!
Former Vendor
Next level options for high horsepower!
Former Vendor
Pricing is current! Contact us to talk all options.
Former Vendor
Cam or Supercharger... both!? A few below and many combinations can be done, let us know what setup is preferred.
NA: https://horsepower-addicts.com/pages...ngray-packages
Boost: A&A Superchargers HPA
Former Vendor
~$4,200 range/ tuning specifics dependent
Former Vendor
Parts, install, and tuning are reflected in the price. Price for tuning varies based on transmission and model year.
