LT4 SC Parts List?
LT4 SC Parts List?
Is there a official parts list of all parts needed to equip your LT1 stingray with the LT4 Blower? I read alot of these install threads but I dont see one that has a listing of parts needed to purchase.
Weapon X or ADM Performance have the “kits”. So, if you have/buy the LT4 blower, they’ll sell you the rest.
There are 2 different Superchargers and you need to make sure you get the correct one. Parts will be different for if you have a dry or wet sump. A dry sump system will not accept a wet sump one as the front snouts are different and pulley wheels will not align. Also the wet sump supercharger pulley wheel alignment (used on cameras and cadillac's interferes with the brake lines on the drivers side. EDGE Vette has a pretty good breakdown of what you need and cost of each item, and Weapon X has a pretty good kit but I did have to get a few extra items when I purchased from them. Some of the list;
Supercharger - id pulley you want 2.5 is standard.
ll gaskets
Balancer and bolt
Air Intake
Tensioner pulley wheel
Tensioner Bolts
Pulley Bracket (sent wrong one 462.01 PN 12663102 reimbursed
Bracket Bolts
Gates Sepertine Belt
Idler Pulley Wheel
Pulley Wheel
Pulley Wheel
Pump
Radiator
Tank
Pump Bracket
Coolant lines
LT4 Valley Plate
Adapter Plates
HP Fuel Pump
HP Fuel Injectors
Brake Assembly Line
Brisk Spark Plugs
Radiator Shroud $55
PVC Tubes 93) $208 12665107 (63.79), 1263620 (41.82), 12646672 (51.45)
Brisk Spark Plugs $18
LT4 MAP Sensor $23
Custom LT1 to LT4 MAP and IAT Sensor adapter harness
Gates Supercharger drive belt
Various fittings and bolts?
Coolant
Custom 12 V relay and wiring harness for Z06 intercooler pump
ll gaskets
Balancer and bolt
Air Intake
Tensioner Bolts
Bracket Bolts
Idler Pulley Wheel
Pulley Wheel
Pulley Wheel
Pump
Radiator
Tank
Pump Bracket
Coolant lines
LT4 Valley Plate
Adapter Plates
HP Fuel Pump
HP Fuel Injectors
Brake Assembly Line
Brisk Spark Plugs
Radiator Shroud $55
LT4 MAP Sensor $23
Coolant
This is what you have to watch out for! It is a wet sump LT4 Supercharger (if it says supercharged on the cover its a wet sump type and will not fit a dry sump engine, trust me I know from experience)
