Meth tank locations
Meth tank locations
I've been reading and reading. Where do you guys mount your Meth ressies? I've seen some people use there washer fluid tank and just relocate their actually washer fluid tanks? or even add an addition tank in the front. I've been looking at the pro meth rear mount. But i heard some issue with the tank being all the way in the back and gravity feeding being a problem. Have those kinks been worked out?
Im thinking about trying to add another washer ressy to the front of the car somewhere maybe next to the stock one someone in the fender? Any recommendations would be great.
I just used the washer tank and never needed washer fluid again. Removed the pump for the wiper blades entirely actually.
Washer tank is easy and no cost. I just coated my windshield to help with things sticking to it so I could minimize the need for wiper fluid.
I had my car done at ECS. The meth is in the washer tank, and they installed a separate washer tank. The new tank is smaller. I find that other than having to keep an eye on the washer fluid level, this was a good decision and would do it again.
Used windshield washer fluid tank
Like above post, I had additional small WWF tank installed and am using the original WWF tank for Meth, added bonus is you get “low fluid level” warning when your meth is running low. The new tank is pretty well see through so easy to check the level of actual WWF too.
