What’s the limit for the c7 fuel fuel system and the bottom end
2nd Gear
I have c7 2016 z51 a8 mods procharger(d1sc) meth(alky dn) and headers (178 tsp)
it’s on 6 psi making 560 whp i want to turn the boost up to 10 will the stock bottom end handle this power and the fuel system ? around how many whp it will be any suggestions?
I'm at 9.5psi with an lt4 blower, injectors and pump and its at 630rwhp. Best bet would be to talk to your tuner and see what they recommend at 560 there is definitely more left in it.
Dont forget @us3rname your using meth as well.
I think i got about 560 without upgrading the fuel, I think im pushing 12psi through the stock bottom end.
Received 1,762 Likes
I think if you are at 12 psi you will have problems IF you do much really hard WOT.. The crank in these cars are forged & good THE WEAK POINT HERE IS THE PISTONS.. The ring gap with them being non forged the ring gap is just to closed for a blown set up..... Robert
I'm ready to build it if it happens.
Thanks again.
us3rname (07-15-2019)
I'm going on about 8 months on my set up with zero issues. I think a lot of people who pop these motors put the blame on component weakness when it was probably a crap tune. I think Cletus McFarland is over 1000 rwhp on his stock bottom lt1 and its still kicking event after being over 800rwhp for god knows how long.
Former Vendor
The ring gaps are very tight. Thats what causes the ring lands to break. I can't tell you how one persons motor is alive at those power levels, but if you looks at the ones that have piston failures. They are all at the mid 600 range and higher.
Billy
Billy
Jeez. You might lose your whole block because you don't want to do drop in pistons now? Wow.
I dont get why everyone is so concerned with what I am doing. I understand the risk. and when and if it blows I'll get it fixed. Im not even 100% sure what i what to do either get pistons or just get a 416. Like i said before i know the risks. When its time to pop in a cam and dismantle the engine i'll do it all once. if it survives LOL
Are you noticing any trends as to what years are experiencing the most failures. I was reading some posts on the Camaro 6 forum that they claim the quality of the pistons have improved throughout the years. Not saying that is the case but am wondering if there is any truth to that statement.
Former Vendor
Its not a problem with the build quality. Its that the LT1's rings are gapped very tight. They all have this issue. For example the stk gaps are as tight as .012. The we do install pistons we set the gaps as high as .022. Give the ring room to grow under hight cylinder pressures.
Billy
Billy
Former Vendor
Welcome and we will form time to time have a customer as yourself that knows the risks and will go mid 600s.
Billy
Billy
Thanks for chiming in Billy.
If you want your LT1 short block to live on boost, then your main concern should be fueling! LT4 in-tank, LT4 HPFP, and LT4 injectors are the bare minimum to run a blower IMO. It’s not just about A/F ratio, you have a very narrow injection window in which to squirt the fuel. Keep your injector pulsewidth under 6.0 ms and if you can, run a little E (E30/E40) to help pull heat out of the chamber. You won’t be able to do that with stock LT1 fuel components and under boost. Running lean and/or detonation will kiss your factory LT1 pistons goodbye. So watch your rail and low side fuel pressures while you tune it in. If those pressures drop, reassess your situation before turning up the boost.
I have all those things Josh! Thanks for the input!
Joshinator99 (07-15-2019)
At 700 wheel or 10+ PSI you need pistons. Anything between 550 and 700 you need meth and or LT4 fueling. HOWEVER....it better be tuned right or like MTI is alluding to you're going to damage a piston.
Ttt
I am just diff if I am going to do this I will replace every dam part in the car to HOPE & try to make sure it sticks together.. Thanks for all your info in the past great shop & vendor here.. Robert
