I picked up this C7 a few weeks ago. Its basically a bone stock LT1 with Procharger kit on it. 4.25" pulley, stock Canned tune from Procharger on it. I plan to dyno it this week to have a baseline. expect mid 500s how it sits.
Planning to add headers, Off road X, and a DOD delete cam. (BTR Stage 2 LT1/4 Supercharger cam to be exact)
Few questions. I know 700rwhp seems to be the limit on the stock pistons (Some say 600). Where does everyone think this set up will land HP wise? Will I need to change the pulley to make up for the headers/cam? I have never added headers to a car that was already blown, normal the other way areound. Or do I allow the boost level to drop with the beter flowing combo and see where power raises to? Is this 700 limit normally when using boost only to get there, or the same with headers, and cam, and lower boost? I don't track the car, drive it on street and some spirited pulls or tire spinning is about it.
Any thoughts on this are welcome.
My last BTR stage 2 cam in a C7/LT1 made 505 rwhp NA. so I would assume similar cam, headers, and low boost should add the same 160-180 HP on top bringing it close to 700 mark?
I wouldn't push the LT pistons passed 600 personally. If you are going to go as far as a cam install then you may as well upgrade the pistons. Most of the motor is apart already. You may as well just pull the engine and do it all in one shot. It wouldn't be much more labor at this point.
Its a lot more money for a drop in piston set (double the cost of a cam), and way more labor. To do a cam, remove the heads and timing cover In the car. I plan to leave the pan in place. vs pulling whole motor.
You will need to pulley it down as you're freeing up some very large restrictions. In regards to the SBE we push LT1's to mid 700 rwhp all the time on oem pistons and I have yet to have a failure to date. The big key is having a tuner that actually knows what the hell they are doing with the LTX motors. Most of them have no clue to be honest.
I will be using a very good tuner. Have trusted him with many big builds. LTx DI stuff as well.
what size pulley should I order to have in hand? 4.25 currently. I am not worried about the boost number as I am the power level. 650-700 is fine for this daily. Just plan for a cam & headers (car sounds so strange to me right now with cats & stock cam been DD cammed LS/LT for 20 years not ha) the cam will help bump fuel, & headers just because so not sure what to plan for if that's the range looking. Dyno & tuner will be lined up so don't want to have to come back later with another pulley. Ect. Want to have it all on hand & be done. Can return a pulley or sell if need be.
Also if I don't do a cam & just do headers, real tune. I assume I will run out of fuel around 600. So what pulley should I be looking for & where can it end up with just blower & headers?
Forget the cam just do meth and a 3.7 pulley.
Unless you want the cam ... but ... if only want the sound of a bigger cam a tuner can make that happen without the $.
I agree on all but would get new lifters & get the upgrade to the rocker arms also. Robert
Do a set of drop in piston when you do the cam. We don't push the stock LT1 pistons past 600 wheel also you will need to go to a LT4 pump and injectors.
Billy
if you plan on doing a cam then the heads and oil pan have to come off unless you plan on not changing the timing chain then the pan can stay on
As stated I do not plan to pull the pan. Car has 30K on it. would re use stock timin set.
But I think current plan is to di headers, and pulley it to 600 and see what I think. Not sure how long I will keep it so cam may be too deep as after 600 start needed meth, and cam, and then we are pushing pistons... ect.. But what pulley for 600 with headers?
Ok good to know. I do not plan to add Meth or E would be great but just makes fuel system limits even lower ha. Do you have headers? What boost level is that at?
Like I said depending on DA I’m usually 9-10 psi. Yea I upgraded all the fuel system and it’s not cheap. But what the hell atleast I’m not putting it up my nose. Lol
