C7, best data as of June 2011
There are MANY threads in this section with posts by people who are smarter than I at engine building that have dissected the article from detroit bureau.
How many long stroke OHC engines do you know of that are turbocharged and spin to 10k rpm. How many of those engines are found in a $50k sports car? Where and when did GM find the time and money to research and build this magic motor? Common sense man.
As far as the vette "playing with existing super cars" I've got news for ya, it already does with current technology.
As far as CAFE is concerned, the MPG target is across the entire fleet of offerings. If GM sells enough cruzes, volts, etc, the corvette can afford to keep current mpg ratings and be just fine.
Long stroke is relative to how the engine is built, which we have no idea how that will be accomplished at this point. There are several high revving small displacement V10's and 12 cylinders out there, so what the concern with a high revving V8?
Where did GM find the time and money to develop and build the most powerful naturally aspirated Small block in the history of the company, where did they have the time and money to figure out how to squeeze 427 cubic inches out of an all aluminum small block that used a dry sump system and titanium rods? Where did they find the time or money to develop a a supercharged engine that develops 630+ HP and has the inter cooler up top instead of below? Common sense man, GM is a rather large company with some serious resources.
There are two cars in the current lineup that can play with the big boys, the Z06 and the ZR1, the rest can't. However, those in the playground did not take kindly to a much cheaper car stepping on to their turf. So they have raised the bar and playing with them is not so easy anymore. There are several comparison where some European six cylinder muscle gave there current top Corvette offering all they wanted and then some with that current technology you think is good enough.
I guess its hard to think about future technology and improvements when you ignore what is happening in the global automotive industry. You won't see the possibilities, nor will you pick up on whats being hinted at with a very narrow focus band. Probably just wasting my time explaining this but oh well, at least its Corvette related.
Received 4,375 Likes
As I said in my first post, I believe there will be several engines offered including the 5.5 as you have stated, but there is an advantage to smaller displacement engine on several fronts. First, if this is to be a true global car that GM wants to sell as a global platform, then the car can not be based solely on what us Americans like. The car must appeal to all target markets. In Europe, a V8 in not the norm, high revving four cylinders and even some three cylinders are.
The Nissan and Toyota's you mentioned have a primary target market and that is here. The reason is because we (the US market) accept the fuel mileage these cars get as more than acceptable considering the gas guzzling SUV's and Trucks we are used to. However, gas prices in Europe are $5-$6 a liter last time I checked, so most there want the most fuel efficient car they can get and that includes a "sports car". Check and see what percentage of these cars you mentioned sell in Europe compared to the US if you don't believe me.
If GM can produce a sports car that has acceptable fuel efficiency, they have a far better chance of success in the European market. Back in the 80's when I was in Europe, one of the coolest cars I was able to experience was an Alfa Romeo GTV 8, this car had a very small high revving V8 by our standards and was a blast to drive. If I could have brought that car back, I would still have it. There is an advantage to a high revving small displacement V8 for a global car, especially if GM intends to market this car as they have stated.
Please name the 190 MPH Sports cars in Europe that use 4 cylinders? How about 3 cylinders. Their market is not people that 3 cylinder commuter cars. They only have one 4 cylinder car with a roof that gets in the 4-4.5 sec 0-60 range and it weighs about 2000 pounds.
The market they are in just doesn't isn't the 3 and 4 cyliinder cars. They are sixes(Porsche) and V-8s and V10s and v12s.
I just don't like the idea of a piston wizzing at 10,000rmp up to top dead center then STOP and change direction back down. The wrist pins and valves all need to move very fast and with very strongs springs, strong oil system, and heat removial due to the friction. Na you can keep that. I also don't want to get on it to pass and see 2000 3000 4000 go damit 5000 6000 6500 yawnn 7000 7500 8000 weeeee 8500 9000 ok this is fun9500 Quick SHIFT
The price of gas in Europe is about $8.00 a US Gallon.
You missed my point and no where did I indicate anything about a "sports car" with a 3 or 4 cylinder engine. the references provided are to point out that small liter engine can make some serious HP and deliver better fuel economy. I already mention the six in the Porsche, you know the one that gave the ZR1 some trouble. We have 4 cylinder cars here that with some work will exceed 190 MPH and I am sure you have seen or read about them. Are they production cars, no but they do showcase the capabilities.
But back to your 4 cylinder sports car question. I guess you never thought of a Lotus being a sports car with its turbo charged 4 cylinder or the Renault Cleo being a sports car with its turbo charged four cylinder, or the Ford Focus R with its 300+ HP turbo charged 4 cylinder engine. Germany, the Netherlands, Spain, and the other European countries have a primary market for smaller displacement engines. Yes there are those with the financial means to own V6, V8 and larger engines, but they are the exception to the rule. In Europe you pay a road tax that is based on the car, in Europe you must maintain tires on the car that are rated for that cars speed capability, in Europe American made cars are far more expensive to maintain due to parts availability and that is why only those with the financial means own a Corvette there period. If you live there, have lived there or ever been there, then you should understand this.
In the US this is not the case, but the market in the US is slowly moving toward smaller displacement engines whether you want to recognize that or not. If you were around in the late 70's, you were able to see what happened and in which direction the automotive industry went in the US. Big V8's were made anemic for fuel economy, 4 and 6 cylinder cars outsold the V8 market hands down. Well we are there once more and everything indicates we will do the same thing again.
Again, if you want to tap into the global market you can not do that successfully using just what works here in the US, you must tailor a vehicle or Sports Car that appeals to the global market. Not sure why that is so hard for some to understand.
1 Post
Oldtimer
Production in June 2013 as a 2014 Model?????
So here comes the 2012 C6; people are ordering already. June 2012 is a year away; and there is another year to order a C6 2013 model?? What happened to "this is the last year (2012) for the C6."
Gas in Norway is over $9.00 per gallon for one.
GM is not interested in keeping the Corvette a niche vehicle just in the US, they want to sell that car where ever they can. Go take a look at the last few years production numbers for the Corvette and see what percentage went overseas, GM wants that percentage to increase. Remember the US is a mature market with very little capability for broad market growth. However, across the pond is a different story and that is where growth possibilities exist if you can deliver a product that appeals to that market. GM needs to make money while expanding its market share and the overseas markets are where the greatest opportunities exist. Sticking with the Big V8's will only tap a very, very small percentage as has been demonstrated thus far with the C6.
The ZR1 is a fantastic car, don't get me wrong on this as I would love to own one. But, make no mistake here, the rest of the sports car industry will not just sit back and do nothing about those capabilities the ZR1 currently has. The difference is they will surpass those capabilities with technology and engineering. In this country we have just begun talking about direct injection, while that has been the norm for some time now in Europe. This is where GM, Ford, Chrysler all need to step up if they want to compete. Ever wonder why the American Automotive industry has such a hard time even maintaining a portion of the US market? Ever wonder why is it so hard for American made cars to sell abroad?
The Corvette is still THE car people think of, when they think of American cars. Especially from a performance standpoint. So even though GM wants to sell Corvettes in Europe, they absolutely cannot alienate their American market base. Also, incase you haven't noticed, most of the manufacturers overseas are increasing the displacement of their flagship cars. The Porsche, the Ferrari, the GT-R, etc are all going to larger engines. The days of big V8s are not gone. Not even close. Technology has come a LONG way from the 70's and 80's.
Another thing about the Corvette, is that it has always been the affordable sports car that has been competing with Porsche for decades, yet at a fraction of the price.
The Corvette's engines get better fuel economy, better reliability, more cost effective, more horsepower, more compact, and probably are even more eco friendly than any of it's competitors.
GM would be much smarter to have another model to market in Europe, rather than trying to appeal to two different markets with one model, and screwing the whole thing up. GM is dumb, but I don't believe they are that dumb.
#33
I agree with you on having another model as that is what they have been doing for years. One version of a car for the US and one version for across the pond. GM has made some really dumb moves in the past and I have my fingers crossed that they learned from those mistakes and will not make the same ones in the future, but who knows.
A few things to consider however, GM no longer has the cash flow or development funding they once had and as a result will need to streamline the production process. This is where it makes sense to try and develop a single version of the C7 that covers all the bases they are after.
What I think will happen is there will be engine choices available as I stated in my earlier post. This will help maintain the appeal here if a buyer wants the big liter V8. I think they will have the 5.5 direct injection V8 and I also think they will have a small high revving turbo charged engine. Everyone is stuck on the 10K rpm thing, but what the article said was "could be as high as" it didn't say thats what it was going to be. GM may even offer some different transmission choices than are currently available. I think if GM follows a process similar to this, they could pull this off and to your point maintain the primary market for the Corvette while providing a product with choices that will appeal to the Global market......
#34
You guys wanting a high rpm small engine just make me wonder. Why do you even want a Vette? Just go get one of these great foreign cars you talk about. These companies have been building them for a long time so they know what they are doing. If you want a Porshe or ferarri or a race car then get one.
In 20 years we will all be driving 10 second electric cars anyway
#35
In 20 years we will all be driving 10 second electric cars anyway:rofl:
#36
So I know about the Lotus. I had an Elise. I am familiar with the turbo 4 Lotus Esprit. It was not a 190mph car in stock form, it was not 0-60 in less that 4.5 seconds in stock form. Try again. The Lotus Elise/Exige could make the 0-60 time with a 8000 rpm clutch drop.
No Clio is a sports car, nor is a Focus. And neither gets anywhere clost to 190mph. They are not compertitors to a Corvette. And not all countres in Europe tax based on displacement. In the UK it is based CO2 emissions on the new cars. And these taxes do not seem to be bothering Porsche or Ferrari, or Aston Martin, or Lamborghini or the Jag XK or any of the other comperitors of the Corvette.
I was around for all cars starting in the 60's The reason the V8s wereanemic in the 70's was due to pollution controls not mileage standards.
#37
#38
#39
Originally you $5-6 per litre. That's like $19-23 a gallon, a far cry from $9. The is a Corvette board, talking about the next generation Corvette. Why even talk about 3 and 4 cylinder cars, unless you were talking about competitors. Who cars abpout them on here. You talk as if the V-8 in the Corvette is the norm here, it is not. The Corvette is not marketed to the "norm". It is marketed to people who want a stylish car that is capable of good handling, 190mph, and fast acceleration to 60mph, or some combination of the above. It is not marketed to those that want 50mpg. The Corvette's competitors in Europe ar at a minimum a 6, and really a turbo 6. The rest are v-8, v10, V12 in at least the ones that match the performance.
One more time, This whole conversation is about which direction the new engine in the upcoming C7 Corvette is going to go. No where in any of my post did I bring up this 190 mph thing you are stuck on, you did. I replied to your comment about the 4 cylinder cars in your opinion not being a sports car. Evidently the Focus R being in rally competition does not register as a sport to you for example. My Z06 is supposed to top out at 198 MPH, so what, not the topic of conversation here we are talking about the new car and engine.
Evidently you missed the time when gas went over $2.00 per Gallon in the late 70's and emissions were not the sole reason the V8's were changed to anemic cast iron bricks, fuel efficiency was. Do you remember the V6 in the full size Pontiac Parisian, Buick's, full size Chevy's, etc. do you remember the 260 V8 that was in the Cutlass, I guess those engines were just put in those cars for emissions also. We will see smaller displacement more advanced engines and you can take that to the bank.
#40
.....The difference is they will surpass those capabilities with technology and engineering. In this country we have just begun talking about direct injection, while that has been the norm for some time now in Europe. This is where GM, Ford, Chrysler all need to step up if they want to compete. Ever wonder why the American Automotive industry has such a hard time even maintaining a portion of the US market? Ever wonder why is it so hard for American made cars to sell abroad?
The reason GM will go with a a smaller 5.5 liter direct injection V8 is because that is all they need to meet their horsepower requirements. They will be able to move up in displacement to get more HP as they need it to sell more cars.
I know why they have had trouble over the years. They let non-car guys and accountants make too many car decisions. They have done a poor job of marketing the advanced nature of their engineering versus the europeans using that complex technology from the 1920's.
