Take a Good Look Here For Whats In Store For The C7
This link will take you to a page on the 2013 Deville replacement. Im sure many of the items mentioned will be found in the C7. Take a look at the video at the right of the interchangable dash display.
http://media.gm.com/content/media/us...6_xts_overview
From what I took from the article almost a guarantee of direct injection, magnetic ride on base model standard, wonderful interior, now this is where the features get interesting for the next vette
Advanced Haldex all-wheel-drive system with electronically controlled limited-slip differential
Magnetic Ride Control, rear air suspension, HiPer Strut front suspension and Brembo brakes – all standard
Standard 19-inch wheels and available 20-inch wheels
Direct-injected 3.6L V-6 with lightweight features, including integrated cylinder heads/exhaust manifolds
Capless fuel tank filler for easier, cleaner refueling
Folding rear-seat headrests that enhance rear visibility
Safety Alert Seat that vibrates to alert the driver
Intervening braking system that lessens or avoids potential collisions
Short- and long-range radar systems that support:
Adaptive Cruise Control
Front and Rear Automatic Brakes
Rear Cross Traffic Alert.
Now the feature that jumped out at me was the ability to opt for awd, I know it has been beating to death, but do you think you could have the choice of buying a rwd vette or awd vette, this seems to be where GM is going also, on the ats you can have rwd or awd, so it seems corvette would be rwd or awd, your thought?
I think the C7 is going to have a bigger leapfrog from C6 than C6 had from C5.
The Consigliere
Received 5,444 Likes
Received 4,375 Likes
I would draw no conclusion from the driveline at all.
Are there some of the electronics and interior items that might show up sure, much more likely.
Automatic Brakes? given the reaction of some to the possibility of start/stop and the controllable anti-slip and handling nannies.... I can't imagine their reaction to this. The Corvette is a sports car not a grannymobile auto pilot car.
Adaptive cruise control - see above
Magnetic ride control is already available
HiPer Strut suspension? Really a strut suspension... what a step backwards.
Heads up is already available
a configurable display... may be interesting based on the design and layout options.
Safety alert drivers seat - will also give me a massage while I am driving? Sounds like a wake me if I am falling asleep thing. Could be good for those long trips through the night. Or if the radar sensed that you were about to go off a cliff... or it could just be annoying. Or it could be entertaining to see if you could fool it into thinking you were falling to sleep. That might be a cool road game to pass the time.
Moving to the quality feel of the newer Caddy interiors would be a step in the right direction. But not too cushy, we need something firmer and more sport racing car like. More metal or carbon fiber and less burlwood.
Let me please highlight that it is shown as a FWD car with an AWD option. Also note that it is a V-6 with 264 lb-ft of torque not nearly the 424 lb-ft of torque of the base Corvette. Also note that the wheelbase is 6" longer to allow more room for that sort of thing.
Finally, the Caddy is a LUXURY car the Corvette is not. Any Corvette implementation of technology may be different for that reason.
isnt the Haldex AWD a take off from Audi (Quattro) where its onlly AWD when it feels the wheels slipping? Otherwise its 2 wheel? Now I know this works for Audi in its FWD cars, not sure if this would work for rwd cars too.
Porsche C4S is something like 90 or 95% rear-drive biased until the fronts slip, then maximum 40% of power goes to the front.
And Saab too?
Transverse engine
[QUOTE=Racer X;1579408659]It is probably a transverse engine, the Corvette is not. So none of the driveline items will transfer.
RacerX,
The transmission is a Hydramatic 6T70, the "T" stands for Transverse, therefore the negine must be mounted transversely. A longitudinal transmission (behind a longitudinal engine) would be a 6L70 or thereabouts.
Regards from Down Under.
aussiejohn
RacerX,
aussiejohn
No I am not kidding. The leaf springs serve no purpose in the geometry on the motion of the wheels. The unequal double A arm suspension of the Corvette does an excellent job of keeping the wheels perpendicular to the road across the pertinent range of motion. It controls fore and aft location as well.
The same cannot be said for a MacPherson (front) and Chapman (rear) struts. They allow much more camber change through the range of motion. They allow more fore and aft motion affecting chamber changes. In a word they suck compared to an unequal double A arm suspension. Their main advantages are space and maybe weight.
So to repeat I am not kidding.
a step backwards is to keep leaf spring suspension, something i am equally concerned with as losing an a arm design although the 911's do just fine with their front geometry with struts.
