C7 rear glass info
#41
I load my bike from the rear, wheels off. No reacharound :P Passenger still fits in the front seat. Much better than installing a hitch+rack etc etc. And I still break records in the canyons on the way to the trails and back
BTW, has anyone thought of how the top will go in there if there's c pillars in the way? Maybe the whole hatch will still lift as a unit. Actually it seems that way even from the Jalopnik renderings. It's not obvious from those renderings, though, what's going with those side windows. Doesn't look mechanically plausible.
#44
#45
Good points. It's possible that the whole rear section will open much as it does now, though looking at the Jalopnik illustrations (which show body seams) I don't see how you'd do that with the side window treatment, unless those windows pop out a bit for clearance.
Of course, one thing Jalopnik clearly got wrong relative to spy photos is the roof. On the spy photos you can make out the same seam along the roof as on a C6. Of course, it's still wider than the center glass... does it go in sideways? Do you have to slip one end in and then drop the other (so it sits off-center)?
.Jinx
.Jinx
#46
Perhaps even utilizing some sort of 'locking/slide mechanism' (highly unlikely of course) to aid in doing it so it's not so awkward?
#49
My 56 has side windows. Nothing new.
#50
Received 1,293 Likes
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
The goal here is to create a new look but to keep the same structure as the C6 which is one of the strong points of the coupe giving us such great access to the large area rear storage. It would be a step backward to reduce that just for change. The costs should be relatively nominal vs something completely new.
#51
Hmm that could be it, the roof panel might actually load long ways (longitudinally) on the new car instead of sideways as has been the case since 1984 maybe.
