Brakes - no more pbr calipers for corvettes?
Anyone notice how none of the test mules had the older brakes? It looks like the corvette brakes are finally going to be brembo for everything.
My guess would be the contract for the pbr brakes will get transferred to the lower road cars and some of the suvs.
Any thoughts or info on this?
J/K - but at the risk of showing my ignorance, what the heck is a pbr brake?
http://www.pbr.com.au/
pbr is an australian company that has had a contract for a while with gm. they make the floating calipers for the base and z51 vettes, as well as the 6 piston/4 piston z06/gs calipers
gm got into a contract with brembo and started using their brakes on the new camaro and the Zr1/Z07 vettes, but continued to use the stuff off the contract with pbr for the rest of the c6 corvettes.
Thanks!
looks like they might. click on the zoom button. http://www.caranddriver.com/photos-1...o-photo-443522
The speculation that the PBR brakes are being totally replaced with Brembos based on the test mule photo might have some merit . . .
But only IF you were certain which model of the Vette the test mule is - And IF you knew the test mules weren't running off the shelf brake parts - And IF you had insider info that PBR wasn't offering a new design for the C7 - And IF GM wanted us to know at this point
The IF's AND's & BUT's are too numerous for me to speculate
back in the 90's PBR was synonymous with vette brakes and otherwise only on the special edition 1LE camaros and b4c police package specials and Cobra 'stangs. They are pedestrian now, but they were deluxe back in the day.
I guess I am confused here ... the few test mule shots I have seen look like they are using the normal Z06 setup. Not sure why GM would feel compelled to change particularly, especially if the C7 is somewhat lighter than the current car.
The Z06/GS uses PBR M-Series that are also available on several Holden models and as an aftermarket upgrade Down Under (see link below):
http://www.pbrperformance.com.au/M-SeriesUpgrade.htm
The history of PBR is fascinating, and it represented the culmination of many of the early leaders in brake design ... Repco, Lockheed/Girlock, and PBR itself. Check it out at:
http://www.pbr.com.au/about/history.shtml
anyway heres a close up picture of a test mule:
The caliper shape is clearly brembo, the rotors are iron, and the diameter isnt very large - maybe 13", which tells me this will be the base or Z51 brake setup.
another shot - while the fronts also look like brembos, the rear calipers are the floating design
one more
That was a good story about the history of PBR, thanks.
When the C4 Corvette was introduced in spring of 1983 a featured item was the Girlock (Girling-Lockheed) brakes.
Girlock evolved into PBR shortly thereafter. Similarly, the C5's Borg Warner 6-speed evolved into a Tremec, and more recently the Dana aluminum Z06/ZR1 frames made in Hopkinsville KY have become Metalsa.
After equipping more and more American performance models, Brembo now has a new manufacturing facility in Homer Michigan. The first US-made Brembo calipers are appearing on the new Cadillac XTS now and the ATS later this summer (even non-performance models). It would seem logical for GM to use Brembos on the C7, whether US-made or imported.
I wonder if the evolution from Goodyear to Michelin will be complete with the C7...
