Will C7 frame be all-aluminum?
If the goal of the corvette team is to have as light a car as possible, they will most likely use an aluminum frame.
I certainly hope all C7s will have an aluminum frame. A lot of optimization can take place when you don't have to accommodate two different materials in essentially the same size and shape (the non-removable roof required to hit GM's stiffness goals). An aluminum frame designed from the ground up can be chunkier to have equivalent stiffness to a steel frame, while still reducing mass. IMHO the C6 implementation was compromised because the initial design of the frame was done with steel, and the aluminum frame had to share the same envelope. I hope now that GM has more experience with aluminum frames, they will have the confidence and abilities to use aluminum for all C7s.
I hope for and expect all aluminum frame but that is something else we probably won't know until at least January.
Although it is for a totally different style of vehicle I found this presentation on the approach used to lighten the 2013 Cadillac ATS quite interesting. You have to cut through a number of slides concerning the competitive design targets to get to the materials section:
http://www.autosteel.org/~/media/Fil...llac%20ATS.pdf
http://media.gm.com/media/us/en/gm/n...4_welding.html
I think it is also possible that they could use some mixture of the aluminum, magnesium, steel, NanoSteel, and other materials.
He says the frame will be made of NANO-Aluminum, and will be so small that frame can't even be seen with out the use of a telescope.
The fact that GM can now more effectively weld aluminum to aluminum will help this happen in the C7 and lots of other GM vehicles.
From the April, 2011 issue of 'Vette'
By Walt Thurn
excerpt -
"A new hydroformed frame (for the C6 Z06) was constructed from annealed, 4mm-thick 5745 aluminum alloy. The standard C5/C6 steel frame is 3 mm thick and weighs 502 pounds, while the Z06 frame is 4 mm thick and tips the scales at 392 pounds (22.5 percent lighter). Even better, the Z06 frame is 50 percent stronger in bending resistance and torsional stiffness. Continuing the theme of ongoing improvement, it's also the first car to use laser welding and self-piercing rivets in a mass-production environment. The final result is that the Z06 Corvette tips the scales at just 3,130 pounds.
Because of the car's low production volume, the aluminum frames are built at the Metalsa (formerly Dana Manufacturing) plant in Hopkinsville, Kentucky. The completed frames are then shipped to Bowling Green for final assembly. In 2009 the higher-performance ZR1 was added to the Corvette lineup; it uses the same Z06 aluminum frame built at the Metalsa plant."
Do I remember discussion that the $131 million being spent at Bowling Green could include moving the aluminum frame assembly into the plant? We can hope.
David
My C7 Website
By Walt Thurn
excerpt -
David
My C7 Website
David
My C7 Website
David
My C7 Website
I wonder if doing the frames "in bouse", having all models across the line using the same frame, and having a complete redesign based on aluminum from the start will offset the extra cost. The base model will surely need to be more inline price-wise with todays base model, and not a current Z06.
Received 4,376 Likes
I have it on good authority that it will have a new TiAlHe alloy an it will only be 2mm thick and have a mass of 100 kg, but do to a Helium fill of the "air" tight frame it will "weigh less than 10 pounds. They will also be using special tires that have a mylar lining so that they can be filled with Helium. While the unsprung mass is changed very slightly this will make the tire/wheel combination 4 pounds lighter per corner.
They are doing amazing things with technology.
Did GM utilize the existing Z frames for all models?. My dealer says all models will have aluminum frames so did GM rework Z frames to handle hatch roofs?
We must keep in mind that Cadillac and Corvette are separate and don't necessarily share technology .
i have it on good authority that it will have a new tialhe alloy an it will only be 2mm thick and have a mass of 100 kg, but do to a helium fill of the "air" tight frame it will "weigh less than 10 pounds. They will also be using special tires that have a mylar lining so that they can be filled with helium. While the unsprung mass is changed very slightly this will make the tire/wheel combination 4 pounds lighter per corner.
In house
When I heard the $131 million I thought that either they were outsourcing a ton or that they weren't making many fundamental changes.
Don't know which. Tooling can be very expensive. Way more than the $131mm I would think.
