C7 Side Fender Vent. Opinions?
Ok Folks, I am begining to think I am the only one who does not care for the side fender vent on the C7. No one seems to be talking about it so I assume people like it. I think Corvette side fender vent styling is a key design feature on any corvette and the vent on the C7, while not ugly, just does nothing for me. Yes, it is large from top to bottom but it lacks any significant ressession into the bodywork (if that makes sense). I would have likes to have seen a larger opening that recessed further into the car. This would have made it look more aggressive. I am hoping that they are saving this idea for the higher performance models. This is a proper fender vent IMO:
Overall, I really like the C7, and I am excited about the "Z" models. I can invision it in my mind based on the base model and it should be a knockout. I just hope that they make aggressive changes to the base car side fender vent like they did with the widebody C6s.
Am I alone in my opinion regarding the side fender vent?
Received 1,293 Likes
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
Looks okay to me. Maybe about the same as a base C6, 1 to 1 1/2 inches?
Now that I see your posted picture of the C7 concept, it looks like they had two choices. Either have the bottom of the cove align with the top of the bottom protrusion that runs from front to back, or the bottom of the same protrusion as with the C7 Concept. Top wins out IMO. Somewhere in the middle would not work at all.
I agree with C6Joy, that it maybe a bit too angular, but i like it overall. And I like the insert. Gives it a more refined, finished look. Also it ties in the the look of the other vents.
The styling of the c7 is awesome. Side vent and all. Very aggressive angle and that's what I like and it's functional
I'm with you Paul. I believe the overriding theme of the car is to have a bunch of exposed black vents. I see a bunch of Rice when I view the red car. The side vents were designed to have a large surface area grille of black plastic . I've seen this on GM's SUVs also.
I would prefer that the cove was more vertical and have the opening 90 degrees from the surface of the fender and located closer to the door. More like the C6 Z06. As little exposed grille as possible.
Same for the scoop on top of the rear fender. Look at the size of of it. Again, it is designed for maximum surface area of black plastic. You don't need that large of a scoop to get air for cooling. Both scoops are designed more for visual effect then for functionality.
Notice how many people really like the photos of the Cyber Gray over the Red Z51 shown at the NAICS. The dark gray helps hide the obnoxious vents tacked on everywhere whereas the red car highlights the black parts.
Regardless, the only vent that bothers me is the side fender one. I hate it for the same reason I hate the base C6 vent and GT-R vent...opening is too thin and does not recess into the car far enough. I've always appreciated the viper vent for this reason. I hope the C7 Z corrects this for me...otherwise as crazy at it sounds, it kind of makes the car much harder for me to like. I keep thinking of the GT-R when I see that damn vent...
[ok, rant over...]
Simple solution: color coded vents will tone them down. I replaced The ugly black spoiler and door handles on my A/O C6 and it gives the car more continuity.
Both the side vents and tail light tear drop vents look atrocious. I prefer the Stingray Concept side vents as it carries forward more of the distinctive Corvette styling. I would have also liked to see round tail lights to pull in and blend better with the round exhaust tips, again maintaining the distinctive Corvette brand. Besides the logo on the front fender, I simply don't see GM's Stingray branding attempt...
I am totally bewildered that Cadillac, GM's other division, has recently created designs that are subtle and quite tasteful then "they can't put the brush down" with the C7. I was hoping at minimum that GM would "shrink wrap" the C6. The C6 was almost perfect- small, clean and purposeful . The C7 side strakes, two tones , contrasting color vents, Christmas bulb headlamps, overwrought side vents are just too much.
Not to mention making the car slightly larger , heavier and carrying over a 5 year old automatic .
First things I did when I got my Z06 as to install the CAGS eliminator, paint the door handles and the rear spoiler the body color(Cyber Gray) and install a M2W.
I'm good with the vents but would like to see (for all the vents) a body-color option. I shouldn't have to remove them and paint them all, IMO.
Hey, at least they are black and not CHROME!
I MUCH prefer these over the GS gills. Way more!
I will have no problem going that route...the C6 Z/ZR1 is THAT good. You can't loose.
Save the flames, as I've posted more than my fair share of off the cuff comments when I feel something sucks. The vents should have been titanium or something. See....
