LT1 SAE output graph
Old May 18, 2013 | 04:06 PM
tuxnharley's Avatar
tuxnharley
That torque curve is way too steep compared to the preliminary numbers GM showed us, which had a much flatter torque curve. This would appear to be a very "peaky" engine.
Old May 18, 2013 | 04:29 PM
CPhelps's Avatar
CPhelps
I think the peakiness of the curves is because the graph only shows the "top" half. If you follow the 320KW down in 10 KW increments, you end up with the Y-axis at about 100 KW, or ~134 hp. The fact that you're not seeing the whole range is stretching the curve's in the vertical direction so it appears more peaky.
Old May 18, 2013 | 05:51 PM
JoesC5's Avatar
JoesC5
I agree as the LT1 graph is stretched horizontally and the "variant" graph is stretched vertically. It does distort them when comparing the two graphs.
Old May 20, 2013 | 03:59 PM
98vert6spd's Avatar
98vert6spd
Im going with 495 will be your number,
I got that with this terrible methodolgy
Caddy cts without DI is 265hp same motor with DI is 304 HP
(((304-265)/265)+1)*430
ends up right around 493 im guessing 495 because corvettes seem to like those numbers. Keeps the Z06 guys happy and who wouldnt love 495 hp. on the flip side they might do a 475hp car first year and go to 495 hp 2nd or 3rd year like they seem to do with new gens.
Old May 20, 2013 | 04:12 PM
RedLS6's Avatar
RedLS6
I took this "sae LT1" graph from the Team ZR1 website, converted it from kW to horsepower, and overlaid it with GM's same graph for the LS7.
Interestingly enough, when I do this, the "LT1" makes about the same power as the LS7 below 4000-4500rpm. This is in agreement with GM's previous claims about the low-end torque of the LT1 being a match for the LS7.
If it's not the real thing, it appears to be at least close to what we should expect.
Old May 20, 2013 | 04:13 PM
Kappa's Avatar
Kappa
I'm still going with 475-480hp with NPP.
Old May 20, 2013 | 04:56 PM
CPhelps's Avatar
CPhelps
I know you already admitted it was a terrible methodology (your words), but just some points to think about.
The LY7 (the 255 hp 3.6L) had 10.2:1 static compression, the LLT went up to 11.3:1, a nearly 11% increase.
The LS3 has a compression of 10.7:1 and the LT1 went to 11.5:1, an increase of "only" about 7%.
That alone will result in less gain from LS3 to LT1 than LY7 to LLT did. Not to mention that the LLT is DOHC making the comparison difficult anyway.
The LFX (LLT's replacement) 323hp 3.6L V6 is also at 11.5:1 static compression, so it seems like GM has settled upon that for their DI engines.
Therefore I'd expect the gains from LS3 to LT1 to be lower. If GM had wanted to limit the LT1 to premium fuel, no doubt they could have pushed for more power.
I'm expecting real close to the 465hp shown in this SAE paper graph.
Old May 20, 2013 | 05:36 PM
JoesC5's Avatar
JoesC5
The GenV 4.3L V6 and the GenV 5.3L V8 have 11.0:1 CR so they can run 87 all the time. Only the two GenV 6.2L V8's have 11.5:1 CR.
All GenV engines have DI, so GM has not settled on 11.5:1 CR across the board for it's DI engines
Old May 20, 2013 | 05:43 PM
SBC_and_a_stick's Avatar
SBC_and_a_stick
completely different head and valve layout so your comparison doesn't work. Truth is the new LT1 had to give up some valve size to acomodate the injector. It is not clear how these tradeoffs work with 4 valves aka a symmetrical layout.
Old May 20, 2013 | 05:53 PM
JoesC5's Avatar
JoesC5
And what do you want to bet that the GenV 6.2L truck engine has a different horsepower than the GenV LT1 6.2L used in the C7.
Old May 20, 2013 | 05:56 PM
SBC_and_a_stick
I'm not sure what your point is. How does it relate at all to my comment?
Old May 20, 2013 | 05:58 PM
DREAMERAK's Avatar
DREAMERAK
St. Jude Donor '12-'13-'14, '16
True, but with DI only air comes through the intake ports, no fuel to be moved through.
Old May 20, 2013 | 05:59 PM
  #33
LS1LT1's Avatar
LS1LT1
And even that's likely on the high side, 460-470hp is still a probability in my opinion.
It will NOT be rated at 495hp, not for 2014 at least.
Old May 20, 2013 | 06:09 PM
  #34
JoesC5's Avatar
JoesC5
My point wasn't directed directly at you, but it was that you can't just extrapolate numbers from various engines(as you pointed out) and not even when the engines are basically the same (as with the GenV engines used in the Silverado and in the C7).
For instance, I can take the 5.3L GenV engine with VVT, DI and AFM and enlarge it to 6.2L, as GM did. If I extrapolate the numbers from the 5.3L version, then the LT1 should only have 415 HP, not the 450 that GM has estimated.
Both the truck and the LT1 versions have the same displacement, the same combustion design, the same compression ratio, etc, but their final configuration is based on their specific application.
Old May 20, 2013 | 06:56 PM
  #35
CPhelps's Avatar
CPhelps
Sorry I mean to say "no higher than" 11.5:1. Meaning even with DI, GM doesn't seem comfortable pushing higher than 11.5, so we shouldn't be expecting as large of gains as the LLT got over the LY7.
Old May 20, 2013 | 07:50 PM
  #36
JoesC5's Avatar
JoesC5
Old May 20, 2013 | 07:59 PM
  #37
SBC_and_a_stick
Gotcha, the version I read was missing all this chunky info.
To LT1 SAE output graph
Old May 20, 2013 | 10:51 PM
  #38
Never-Enough's Avatar
Never-Enough
That would be nice. I am still eager for the races/dynos between stock C6Zs & stock C7s to commence so we can see the results.
Old May 25, 2013 | 11:43 AM
  #39
JoesC5's Avatar
JoesC5
455 hp.
Old May 25, 2013 | 08:08 PM
  #40
Chonger's Avatar
Chonger
LS7 > LT1 plus the Z weighs less, especially the earlier models. This is no rip on the C7 at all. I still suspect the car will trap 118-120.
