Why didn't GM increase the bore spacing on the GEN V Motor?
The Consigliere
Received 5,447 Likes
Would be considered sports car blasphemy to change the small block bore centers.
Kind of like why Porsche artificially holds down the Cayman in power so it doesn't unseat the 911 which has an inferior drivetrain layout.
Atho, the latter should happen IMO, but not the former.
AIR FORCE VETERAN
I am biting the bullet and buying the 450 HP C7. I have learned to suffer from years of driving low horsepower 435 / 427's, and 375 HP mechanical fuel injected small blocks, those who want more will get it when the demand slows.
It is just a matter of learning to accept the things we can not change..
It seems strange that if GM spend $1,000,000,000+ developing the LT1 that they wouldn't have increased the bore spacing slightly to accomodate a larger displacement motor on the same architecture base (since it really wouldn't cost anymore). Yes, I understand the push for fuel economy, emissions, etc, however, for an all out performance N/A motor it seems this would be easily accomplished via more cubic inches and the fact that this larger displacement derivative motor could find it's home in Trucks, SUV's, Motor homes, large industrial trucks, etc. since forced induction motors typically get less economy.
Optimum size, weight and packaging. Don't mess with a good thing.
Starting with the 265, then 283, then 327, and all the way to today's LT1, the 4.4 is the longest running engine family in automotive history.
They don't change it because it is a winner ... a bit of automotive genius if you will.
As many on here know, the 4.4 "small block" is actually NOT a small block. The term "small block" is simply a GM in-house nickname ... an unfortunate choice ... that just sprang up internally after the bigger blocks like the 454 and maybe the 409 (?) were born. They could just as easily have nicknamed it the "power house" or the "super block" or perhaps more wisely, they should just call it what it is, the "4.4" ...
Unfortunately, machismo and ego being what they are, nobody wants a small block, "Mongo want BIG BLOCK!"
Think of "small block" as an affectionate nickname for one of the greatest engine designs in automotive history. Just remember it ain't small.
Received 3,805 Likes
"Ask Tadge" Producer
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
You have a clean sheet of paper...what's a few million dollars when you're talking a billion!
Those machines aren't going to last forever and you'll have to replace them sooner or later, just bite the bullet now on Obama's nickel!
Joe, let's get serious.....hundred's of millions of dollars to accomodate less than a 1/2" longer block (adding 0.100" to the bore spacing times 4 cylinders) and maybe 1/4" in width.
And hey, I am so tired of dicussions about tail lights and why the LT1 isn't rated more than 450HP that I thought we could use a new topic to debate
And, WADR, therein lies your problem, OP. You think it's the President's money when, in fact, it's everyone else's money---yours, mine, every GM worker, and every non-GM worker.
You also don't seem to give serious consideration to JoeC5's points above. Because it really ISN'T all about the money. But money does count---especially when it's not yours, or just yours to the tune of 1/311 millionth.
I guess, Ford, Audi, BMW, hyundai need to stop making turbo cars.
Another point of fact. Taking a turbo / supercharged engine and making it NA, you get even more efficient. There's a loss of energy by trying to compress the air to use it. But this is not the place for that debate...
#33
The Consigliere
Compression ratio makes the biggest impact on fuel economy. The higher you can run compression on an FI engine the better fuel economy you'll see. That's the main reason for the difference in fuel economy b/n an LS7 and an LS9, the latter having a significantly lower CR.
#34
#35
The other reason being the environmental & safety lobby from DC pressure GM to spend all it's money on boring things nobody wants. And unfortunately the crooks have a stranglehold on Big Gov.
#36
I think GM should have put the LS7 in. So I'm sure the 1st reason GM didn't do it is because it would increase the base price too much. And probably hurt sales.
#37
As for the "boring things nobody wants", I'd really like you to not talk for me. If by boring things you're referring to DI, VVT and/or AFM, you're wrong. I want all 3 of them.
The LS7 is prohibitively expensive. It uses titanium for lots of parts. In special lower production volume cars it makes sense to have such an expensive motor. But when you're going to mass-produce 20-30K cars per year, the cost of that titanium would actually go up... Not down. That's using a LOT of titanium, an already rare metal as it is.
I will DEFINITELY take the LT1 over the LS7 any day.
