Now that we know the hp number is low why does everyone think they will up the power?
#561
But like gthal basically said, run what you brung. As it sits, the GS ran a 2:54.5 and the C7 Z51 a 2:51.78. Period. There's no equalizing with similar tires or adding an intake and tune or anything. It is what it is. At VIR, C6 ZR1 > C6 Z06 > C7 Z51 > C6GS. Exactly how it should be given the numbers.
The gap between the C7 Z51 and C6 Z06 is the same as the one between the C6 ZR1 and C6 Z06.
Side Note: Jim Mero mentioned that the factory cars might be able to run even quicker times due to the sheer amount of datalogging equipment in the back of the prototypes.
#562
Engineering calculations indicate that 31 additional hp, or 467 hp, would be required for the C7 design, to compensate for the additional weight.
Therefore, the C7 is actually 7 hp shy of the break even mark.
What are these folks thinking???
#563
I cannot understand the constant comments regarding that 24 hp increase over the C6 LS3.
That's why the Z51 still goes 0-60 more quickly than any LS3(at least by GM numbers) and traps 119mph according to GM.
#564
This thread, like most others in this section, is nothing more than a big pissing contest. Seems like it's mostly written by children. Seems like that's what this place is all about lately. Boring listening to many of you talking about who's dick is longer - no one gives a ****. It's an embarrassment in the community. Sounds like the Viper boards around here. They'd toss most of your a$$es outta here permanently if this was the Ford GT forum.
#565
#566
I know of no "engineering calculations" that require 31 hp to compensate for the weight increase. Total BS...I guess I'm just sooooo tired of hearing about this 24 hp, like it was an important consideration in purchasing a C7, and then bashing the C6 for limping along with 436.
Like FastestBusaAround said, so many threads these days turn into a pissin' contest, over absolutely nothing....I hang around for the entertainment. Although earlier I watched "Road House" for the 3rd time, and enjoyed it more.
#567
Scraping the splitter.
Hee, I gotta admit that my comments were purely sarcastic.
I think at this point, the speculation and BS should end and people should be watching for real performance numbers to start being published. This will, IMO, end all the nonsense about how GM "dropped the ball" with the C7. Once these cars start getting tracked, it will become even more apparent that it's a step up from the C6.
S.
#568
S.
#569
S.
If the C7 turns out to be everything that G.M. says it will be, and if there are no issues associated with the new beast, and if it is a significant step up from my '13 GS to warrant the trade/sell expense, I will order one in July, of 2015. If all that criteria is not met, then I'll continue to enjoy my C6....simple.
For me, everything else is just speculation, personal opinions, and fanboyism, to one degree or another.
#570
Just messing with you. I totally agree with you.
#571
I think this one has long since outlived any usefulness it may have had
