Why is rev matching an on/off situation
16 Vettes and counting…..
I had a 370Z with the rev match feature. It's a blast....the first time you try it you won't be able to wipe the smile off your face.
Nissan has had it in the 370Z for years. Having driven one I can't say I care for it, but if it increases sales of manual transmission vehicles that's a good thing for the Corvette.
We want people buying MT vehicles, and if the rev matching features helps so be it. If people don't buy them, some day they will be cancelled. GM needs to make money on MT's or they will stop making them.
A synchromesh is a passive mechanical rev-matcher. Is that cheating?
Almost everyone on this forum, including the heel-and-toers, are relying on the synchronizers to help them out whether they recognize it or not.
Received 4,116 Likes
2020 C8 of the Year Finalist - Unmodified
But it's matching the speeds of between the gears, not the engine. To get the best performance, you want to match both while adjusting the throttle.
If GM had a DCT, there would be no manual at all. The younger buyers they're supposedly aiming for have none of that old school passion for a manual. Besides, a good DCT will smoke the equivalent manual in acceleration times.......and that's all that really matters, right? The writing's on the wall. The only reason Porsche still offers a manual is because of the Porsche purists who still want them but the numbers are dwindling....or dying off. You can't buy a new Ferrari with a manual. The day is coming.......
Not all the kids but a vast majority can't drive a stick shift car...they are afraid....
I've been driving manual transmissions for over 35 years and I'm still not all that fast at it. I love it...but driving wise..ill never be a Ranger...lol
DCT would be cool but rev matching and launch control will suffice if DCT is not available,,
Is rev matching cheating ...only if PTM and ABS is as well..
The m7 is a cool advancement....and till DCT is available...I'd go that route.
This C7 rev match features does nothing for the synchros, in fact, it is worse because the engine speed is much greater than the transmission speed???
There are 3 iron sincro rings on first and second, 2 on 3rd and 4th, coated with carbon molly compounds like auto xmissions and DCT have.
ZF cautions against double de clutching because the rings wont line up which will cause blocked shifts. You don't care about the life of sincros anymore.
I think they put auto blip in for warranty reasons. The problems with damper, dropped valves, timing chain wear, etc. were caused by lunatics that couldn't heel and toe. You hear them at the track events all the time. It makes me sick. They should be fined and flogged.
Many so called racers just shove it into the lower gear and pop the clutch which accelerates the engine faster than it was designed for. Not to talk about the reversal loads of the drive train. 60s rally drivers would do purposely it to get the tail out. You have tools you can use only if you understand the machine.
Left foot braking and heel toeing is essential in braking, acceleration transitions which the auto blip can't do. Also when you take off from and incline, only extremely horrible low class Obama supporter types use the hand brake.
You don't double-clutch?
#33
I look forward to trying it out. I don't heal/toe very well, will never track my vert and couldn't be bothered to learn to perfect heal/toe. If the feature works well I'll use it, if not, no loss, I still enjoy manual transmissions. Cars like Corvettes are toys, if technology makes them more enjoyable then that's great
#34
The Consigliere
Received 5,432 Likes
I think it will be fun to play around with.
Probably won't use it all the time.
#35
Drivers heel-and-toeing a car with big stout healthy synchronizers may be unaware of what an assist they're getting. I suspect if we secretly replaced their Tremecs with crash boxes, Folgers Crystals-style, there would be lots of grinding and wincing.
#36
Not really the same thing, as the rev matching in the C7 is to match the engine revs with the drive line so the when the clutch operates there it no speed difference and hence a super smooth up shift or down shift.
#39
You're right, the only reason I rev match today is because my transmission grinds during downshifts. It is more than just rev matching the engine with the clutch pedal pressed to the floor. I have to release the clutch pedal before the rev match and press the clutch again for a smooth downshift without grinding gears.
If you put the shifter in a gate and hold the clutch in while you're at speed, the engine will maintain the correct RPM until you let out the clutch. As the vehicle speed slow while coasting, the engine RPMs will continue to match the expected input speed on the transmission.
Will have no affect on the sincro life. Double de clutching with old single silicon bronze sincro rings did that job. Heel toe, double de clutch, left foot braking, ah, those were the days. I still do it sometimes because of the imprint in left in my brain.
The engine matching the expected input speed prevents the need for the syncros to crash or spin up/down as fast. The gears mesh without the syncros working (or working hard).
#40
Nissan engineers explained that automatic rev matching indeed saves the life of the syncros and the driveline as a whole. The GM version isn't different than the Nissan version.
