rev matching question for owners
Received 4,116 Likes
2020 C8 of the Year Finalist - Unmodified
Any of you guys who have gotten the manuals.... I have a question.
Can you use Rev matching to go from neutral to first? That is, if you're stopped and in Neutral, can you just let out the clutch with the car in 1st and it will rev match to engage smoothly without using the gas pedal?
For me, I don't care. I drive a manual everyday.
But for my GF (whose skills are not so good with manual shifting), I wonder if the Rev match would make it easier for her to drive in stop and go traffic. I'm sure others would want to know also.
Anything weird you've found in rev matching yet?
Thanks!
Thanks!
I am pretty sure rev matching only occurs during a downshift when the car is moving. The scenario you described would result in stalling.. if the engine revved while in 1st and not moving that would be dangerous and could result in something very bad. Imagine letting the clutch out and the car accelerates Prius-style into the car in front of you.
Question doesnt make sense. If you are in neutral and stopped at a light with the engine at idle and the clutch engaged, the input shaft will be at engine rpm and all the gears inside the gearbox will be rotating. The output shaft will be stationary. If you put your foot on the clutch pedal, it will take a while for the gears to slow down so you should hesitate before placing the shift in first which will add a little life to the 3 sincros on 1sr gear. The rev matching can't do anything unless you are moving at a faster speed than engine idle. If you take it out of neutral and place it into first whilst rolling, the rev matching will take place.
I have a C6 with a manual and even without rev matching I don't have to give it any gas to get moving from first, not even on a hill. I would bet the same holds true for the C7.
Sounds like time to take the GF to the local shopping center and get her used to starts in a manual.
Hope this helps!
Nope; sorry but ARM is just for switching between gears. If you are rolling and put it in neutral and then attempt to put it in 1st, it should attempt to bring the revs up (assuming it's switched on) but from a standstill, you're on your own.
Hope this helps!
Hope this helps!
I was gonna leave it on Valet for her. I think 450 HP is just a bit too much for high heel shoes.
The Consigliere
Received 5,444 Likes
I have a C6 as well and you don't have to give it gas for the car to move out of 1st gear. It goes no problem....
It would be nice if they'd block the gate, kinda like the 1-4 skip shift to avoid a $shift but alas, either the mfg's haven't thought about that, it'd be to expensive and heavy to add to the car, or they just don't want to give up those non-warranty repair claims - thus the name "Money shift." .
Cheers,
C
It works great going into any gear where the wheel speed exceeds that needed by the engine, and thus blips the throttle. It also works to settle the throttle on upshifts - much more subtle and easily overridden by a mistake from the driver but it does it's best with what it has and a very nice job at that.
Long answer to a short question, I know but figured I'd head some others off at the pass...
Cheers!
C
First hand experience over the last few days:
It revs match up and down. and if you put the shifter in gear and hold the clutch down, the computer will hold the rpms where you need to be, adjusting for increase or decrease in speed (like rolling up or down a hill) its pretty slick. If you downshift into first it will not rev match. If you are trying to move forward it will not.
You do need to use the gas pedal for the c7 to get going, you WILL stall it
