** C7 Reported issues and resolutions thread **
Old Nov 15, 2013 | 03:14 PM
  #461
LT1_E85_Corvette's Avatar
LT1_E85_Corvette
The outside of my car rattles on the passenger and driver side door really bad when I have my speak up half way. Is this normal? Bass isn't even up all the way; however, it sounds like i'm driving a 1999 Honda civic with 18" subs in the truck. Really sounds cheap.... This normal?
Old Nov 15, 2013 | 03:41 PM
  #462
BPhillyc8's Avatar
BPhillyc8
Not normal. The stereo sounds great with some adjusting. Adjust the Bass, Mid and Treble. You also may want to move the speakers selection dial a little forward to favor the front end of the car (and less subwoofer). Also play with the modes. My favorite was the one all the way to the right (I forget what its called without having it in front of me). If yours is on "driver" its gong to default with more low end rumble for some reason. Hope this helps.
Old Nov 15, 2013 | 05:39 PM
  #463
iclick's Avatar
iclick
Originally Posted by CaryKen
USB MEDIA DEVICE SOMETIMES NOT RECOGNIZED:
USB memory stick with approximately 6000 songs and perhaps 40GB of content inserted in center console port. Usually plays fine. But occasionally upon starting the car, the audio display tells me that no media device is found. I cannot browse, skip, or pause the music that is still playing from the media device! Resolution is to turn off car and accessory power and then restart. Has happened twice so far. I have not reported it to dealer.
Originally Posted by bbrown450
I have the same issue on my new Caddie ATS but found out the system has to index these songs "each" time and with 6000 songs it is not a quick process...give it 5 mins or so before you attempt to access...
You might try categorizing the songs into folders with <20 songs each. I had the same problem with my Garmin Zumo GPS MP3 player and the folder trick cut the loading time from minutes to maybe 10 sec. I used folder names like Ab-Bz, Ca-Eb, etc. throughout the alphabet corresponding to the song title, again keeping the songs to around 20 per folder.
Old Nov 15, 2013 | 06:10 PM
  #464
billyskis's Avatar
billyskis
Default memory recall
Took delivery of vin# 5507 NRB, Z51, 7speed and started playing with the settings today. Looks like some others have complained about the “memory recall/exit” on the driver’s seat. My question is, why should you have to hold the button in with to motor off and you only have to touch the button with the motor running? Do I have something set wrong?
Old Nov 15, 2013 | 07:31 PM
  #465
BPhillyc8's Avatar
BPhillyc8
Go into your setting menu and you can set it up automatically. Works great, nice feature
Old Nov 15, 2013 | 09:07 PM
  #466
NOMRW8NG's Avatar
NOMRW8NG
No, you don't have something set wrong. That's how it works (at least with an M7). Doesn't make much sense, does it.
Old Nov 15, 2013 | 09:28 PM
  #467
Slappy3243's Avatar
Slappy3243
I wonder if the rattle in the right front of the hatch could be the strut bar that supports it when open. There is some play in it when the hatch is open so I am assuming there will be play when it's closed.
Old Nov 15, 2013 | 10:33 PM
  #468
SCM_Crash's Avatar
SCM_Crash
I sincerely hope they have an update coming for this. It's REALLY annoying.
Old Nov 15, 2013 | 10:47 PM
  #469
No Shot's Avatar
No Shot
Originally Posted by No Shot
My C7 is 24 hrs old. the LED display on the Driver's climate control **** has died. Anyone else?
This morning, went out to car and LED on **** was working fine. Just waiting for it to go out again.
Old Nov 15, 2013 | 10:56 PM
  #470
thedofuss's Avatar
thedofuss
have her name and contact info? sounds like you found a winner.
Old Nov 15, 2013 | 11:34 PM
  #471
Slappy3243's Avatar
Slappy3243
Sounds like the behavior of a backlit LED switch I had in my GTO. Some days it would work while others it wouldn't. Over time, the soldered connection corroded some I guess and became week. In your case I am willing to bet the soldered connection isn't great. It happens and should be an easy fix.
Old Nov 16, 2013 | 12:05 AM
  #472
Jpiatchek's Avatar
Jpiatchek
Default Infotainment update
Originally Posted by Jpiatchek
My infotainment screen started flickering and bouncing up and down on the way to work today. At first, XM radio went out, then screen started bouncing up and down. Did the same thing in reverse with the camera and on all screens.
Shut it off and on several times during the day and still the same
Dealer said to bring it and it was still doing so when I got and they documented with a video.
They gave me a nice Impala to drive with 2800 miles on it with full leather and XM radio.
They also said they had a bulletin on it saying it would be fixed in Feb.
VIN 1238 with 1700 miles and no other problems.
I told them I didn't want to see it in the shop for ten days while they waited for parts.
They seem like they understood. We will see in the next couple of days. Sure don't want to wait to Feb to get it fixed.
Well, Thursday and Friday came and gone and no parts. Evidently they are in short supply and was told they will be in the middle of next week.
They put the all parts back in and put the dash together and returned my car today until the new parts come in.
Surprise, surprise, surprise! It works perfectly now. Go figure.
Do I have the new parts installed when they come or drive it until it malfunctions again?
John
Old Nov 16, 2013 | 08:45 PM
  #473
Mike1975az's Avatar
Mike1975az
John
Have the new parts installed for sure. Why take the chance. These parts are in short supply, take them before somebody else does. Trust me. I've had the same issues. I got a new screen and all has been ok. Still have rattles tho
Old Nov 16, 2013 | 09:30 PM
  #474
Jpiatchek's Avatar
Jpiatchek
Default New parts
Sounds like good advice. Thanks
Old Nov 17, 2013 | 07:30 AM
  #475
2vetteEd's Avatar
2vetteEd
Originally Posted by vetehead
Vin 1356 ...z51 2lt nav npp manual magride ...
Hatch closing issue...software bugs with with the following:auto memory recall does not seem to work properly as well as easy exit recall. Remote left in vehicle seem to chirp 3 times with car running and I get out of car with remote in my left pocket..... every time??....I will update here if I find anything else.
Premier Edition #142/500 3LT/Z51.
Hatch closing issue. The hatch won't snug down without a firm push with the flat of my hand. I'll have it looked at by my dealer whenever I go back his way. I won't make a special trip for this.
Old Nov 17, 2013 | 08:13 AM
  #476
No Shot's Avatar
No Shot
If you close hatch properly, it's not a problem. Be firm. There's a YouTube video on it..
Old Nov 17, 2013 | 08:17 AM
  #477
No Shot's Avatar
No Shot
Vetehead,
There is no problem with your seat setting. Even though they are not marked, the key fobs are assigned to setting 1 and 2. Try the other fob...you will be fixed. I just went thru this yesterday. Even the dealer didn't know this. This is same as C6's. let me know if it works for you.
To ** C7 Reported issues and resolutions thread **
Old Nov 17, 2013 | 09:05 AM
  #478
TAP101's Avatar
TAP101
8th Gear
Vetehead,
If you remove the key from the FOB, you can just see the 1 or 2 in one of the indentions of the key base.
Old Nov 17, 2013 | 09:14 AM
  #479
irpete's Avatar
irpete
Can you post a picture of this? I've heard it said before but have looked there on both keys and can't find it. I even mentioned it to my dealer (Kerbeck) on delivery and was told that that's the first they've heard of that. We looked with the dealer and couldn't find it then either.
Old Nov 17, 2013 | 09:35 AM
  #480
TAP101's Avatar
TAP101
8th Gear
Here ya go
Originally Posted by irpete
can you post a picture of this? I've heard it said before but have looked there on both keys and can't find it. I even mentioned it to my dealer (kerbeck) on delivery and was told that that's the first they've heard of that. We looked with the dealer and couldn't find it then either.
