HUD Display Tilted
Old Nov 11, 2013 | 09:19 PM
F4Topgun's Avatar
F4Topgun
Default HUD Display Tilted
The HUD works perfectly but but it is tilted approximately 5-10 degrees clockwise. I've had a couple of different people look at it and all have agreed that it is tilted.
Has anyone else seen this?
Did you try and fix it, were you successful and how?
Old Nov 11, 2013 | 09:22 PM
RicK T's Avatar
RicK T
I don't think it actually is. Read this and see what you think:
http://forums.corvetteforum.com/c7-g...ly-tilted.html
Old Nov 11, 2013 | 09:38 PM
F4Topgun's Avatar
F4Topgun
I read through the entire post. I believe the consensus (80-20) was that the display is tilted and that no one has found it annoying enough to go to the trouble of having it fixed. As one member, the weather is getting bad and maybe it is time to take it in. RAD22 suggested it is caused by the curvature of the wind shield. Moving the HUD up/down effects the tilt. I'll check that out tomorrow.
Old Nov 11, 2013 | 09:43 PM
RicK T's Avatar
RicK T
Okay. Just offering what I've seen, since I don't have a C7. Hope it works out with no problems.
Old Nov 11, 2013 | 10:33 PM
DRDR's Avatar
DRDR
I've noticed the same thing, if it is from the hood or even the curve of the windshield can't it be overcompensated by tilting the actual device in the opposite direction so that it appears straight to the driver?
Old Nov 11, 2013 | 10:38 PM
runutzzzzz's Avatar
runutzzzzz
I moved it around and it still looks tilted. My car is in for service right now and that's on my list. We will see what GM will say but I'm guessing they are going to come back with "Functions as intended" LOL
Old Nov 11, 2013 | 11:03 PM
C06's Avatar
C06
It is tilted. NO QUIESTION ABOUT IT.
Old Nov 11, 2013 | 11:58 PM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
lol...I actually have my HUD dimmed down so it is not visible. I don't like or need it.
S.
Old Nov 12, 2013 | 12:02 AM
Jesse's Avatar
Jesse
Retired Admin
Founder St. Jude Fundraiser
Originally Posted by Snorman
lol...I actually have my HUD dimmed down so it is not visible. I don't ... need it.
S.
Old Nov 12, 2013 | 12:08 AM
slief's Avatar
slief
I've got a C6 with HUD and the display is also "tilted". I think its an optical illusion caused by the hood.
Old Nov 12, 2013 | 12:26 AM
Jesse's Avatar
Jesse
Retired Admin
Good point
Old Nov 12, 2013 | 03:03 AM
SCM_Crash's Avatar
SCM_Crash
Mine isn't tilted.
I don't think it ever looked tilted. I made sure by parking the car face into towards a wall that has lines running horizontally. It's not tilted.
Old Nov 12, 2013 | 08:31 AM
Hot Rod Todd's Avatar
Hot Rod Todd
My dealer is working with GM to see if there is a way that they can adjust the tilt. As yet I have not heard anything from them. Surprised to hear someone has one that is actually not tilted, since every one I have seen is. Some think it's an optical illusion, but in reality there is a slight tilt to the right. Dropping it down towards the hood does take away some of the tilt, but it is still not straight.
Old Nov 12, 2013 | 08:48 AM
nichtlangsam's Avatar
nichtlangsam
I am so busy making hard left turns that it appears correct to me.
Old Nov 12, 2013 | 11:38 AM
Steve Garrett's Avatar
Steve Garrett
CORVETTE TODAY Show Host
CORVETTE TODAY Host
St. Jude Donor'15
^^^^ LOL....mine is tilted too. I just thought it was supposed to be that way......
Old Nov 12, 2013 | 11:46 AM
LimeRay's Avatar
LimeRay
GM knew what they were doing.
Old Nov 12, 2013 | 12:37 PM
Glenmcp's Avatar
Glenmcp
It does appear to be slightly tilted to the right, but it is so slight that it is not a issue for me. And, I do not want a technician messing with it as it works perfectly.
To HUD Display Tilted
Old Nov 12, 2013 | 12:39 PM
Mojosan's Avatar
Mojosan
Mine appears tilted. Slightly lower on the right.
Old Nov 12, 2013 | 12:47 PM
FrancisDGarcia's Avatar
FrancisDGarcia
I think most of us are just spending too much time in the fast lane which slopes a little to the left. That kinda forces the driver to lean a little to the right, hence, the HUD tilt issue.
Old Nov 12, 2013 | 12:49 PM
khoeysr's Avatar
khoeysr
Corvette fan
No problems with my car. HUD is nice and straight.
